408 build thread 98 ss
Old Jan 17, 2016 | 09:13 PM
handyandy496's Avatar
Sounds like fun!
sweet99ss's Avatar
Originally Posted by LS_86Cut442
Do you have any dyno #s from an engine dyno? My goal is 10s also. I have an ls 403 with l92 cnc'd ls3 heads but I'm running a th350 and 3500 stall so I'm just curious.
I don't even have engine/transmission yet lol. All I've done so far is pull the stock engine/tranny and sell it. Still saving for the 408 and then I will buy tranny. What is your 403 in? And what weight? I ran a 12.3 with a full weight bolt-on ls1 engine with stock cam/ **** heads and a little 3200 stall. So I'm really thinking a 408 with big cam, better heads and a bigger stall should do 10's..
Old Jan 17, 2016 | 09:18 PM
LS_86Cut442's Avatar
The 403 has the l92 cnc ls3 heads 235/243 624-624 cam all the internals are forged here's the dyno sheet... Those are the numbers at the flywheel not rear wheel
Old Jan 17, 2016 | 09:21 PM
sweet99ss's Avatar
Looks pretty stout. With the right weight and tire setup I would say it should go 10's as well!
Old Jan 17, 2016 | 09:26 PM
Thank you! That's what I'm hoping for! It's in an 86 cutlass 442 so it's a pretty light car. The aluminum block should lighten it up even more. Doesn't have ac and it has billet street lites for wheels. Running a 275/60/15 right now for tire and it has the stock 8.5" 10 bolt with 3.73s
Old Jan 18, 2016 | 10:51 AM
kinglt-1's Avatar
try hitting up 01ssreda4. He runs a very fast auto /10-bolt car. Probably give you some pointers to go farther than 72' down the track.
I do not think he still has a 10 bolt.
Old Jan 21, 2016 | 11:55 AM
sweet99ss's Avatar
Anybody know if my valve covers will need to be modified with ls3 heads and what else has to be done for the 408?
Old Jan 21, 2016 | 12:23 PM
Darth_V8r's Avatar
Moderator
You're right. I noticed it a few days after making that post, which is probably long after he ditched it. But he did do a hell of a job going very fast, very reliably on a ten bolt.
Old Jan 21, 2016 | 01:26 PM
mjs1012's Avatar
senicalj4579 ran 10.9x with a h/c/i SBE with no suspension work at all, 10 bolt, and ss3600 stall, and he drives it 2+ hours to the track, so with a good launch I think you will run in the 10s with that setup. Op, are you going to run the heads stock or have them ported/milled at all?
Old Jan 21, 2016 | 01:48 PM
Th350 and a loose 3500 stall
Old Mar 11, 2016 | 11:27 PM
sweet99ss's Avatar
So here is the plan
ENGINE:
TMS 408/L92 heads
23x/24x .60x .60x cam
Ls3 intake/90mm TB
FTRA setup
TRANSMISSION:
LVL 5-6 rpm 4l60e
Circle D 4200 Triple disc stall
OTHER:
Weld Rts wheels
Skinny fronts/28" rear
No A/C
No spare.
I'm thinking this should be a solid 10 second car what about you? Will run N/A for quite a while and then plan to hit it with a 100 shot or so.
Another big goal of mine is to also pull the wheels. Any reason I shouldn't be able to do that with this setup N/A?
So I'm sticking pretty close to the original plan. Here is What I have ordered so far.
Engine
Tms 408/l92 heads
BTR .660 Springs
242/254 .620 .612 lift
LS3 intake, LS3 Injectors, and Holley 90mm Throttle body
Transmission
RPM LVL 6
Circle d Triple disc 5c 4200 stall
OTHER:
Weld Rts wheels
No A/C
No spare.
Things still needed
Torque arm relocation crossmember
SSRA Mega Mouth
MAF of some kind? Undecided
B&M trans cooler
Old Mar 21, 2016 | 09:19 AM
  #32
z twenty h8's Avatar
I remember reading about the baffle needing to be removed in order for them to fit. Can't remember which thread i saw it on.
A guy to a dremel and pliers to the baffle and it fit fine afterwards.
EDIT: https://ls1tech.com/forums/generatio...ls3-heads.html
