BTR Stage 3 vs BTR Stage 4 cam???
Old Jan 20, 2016 | 10:49 AM
mcginnis22's Avatar
Default BTR Stage 3 vs BTR Stage 4 cam???
Just wondering the difference in these two cams. The rwhp, driveability, powerband.... That type of stuff. Can't really decide which one. My car is a 2001 z28 with basic bolt ons and is only out on the weekends. Just wondering the difference or is it just splitting hairs with these two?
Old Jan 20, 2016 | 10:52 AM
HCI2000SS's Avatar
Can you list the specs?
Old Jan 20, 2016 | 11:02 AM
BMR Sales2's Avatar
LS1Tech Premium Sponsor
I have had good luck using both cams as they both perform very well. The stage 4 cam is about as big as you can get before you have PTV clearance issues. It is a big nasty cam that makes power higher up in the powerband. With the cam being so large the driveability suffers a bit but it can definitely be driven on the street. If you have an auto transmission you definitely want to have a good sized stall with this cam as it will absorb some of its bad habits. The Stage 3 cam is a little smaller and doesn't make power as high in the powerband but will offer better low end grunt. The driveability on this cam is very good with a good tuner. Since it the car sounds more like a fun cruiser I would go with the Stage 3 out of both of them just due to better driveability.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old Jan 20, 2016 | 11:06 AM
mcginnis22's Avatar
Stage 3- 231/242 .617"/.592" 112+2
Stage 4- 235/242 .621"/.592" 111+3
Old Jan 20, 2016 | 11:40 AM
HCI2000SS's Avatar
The 4 would be fun if the car is a 6-speed and has steeper gears, otherwise the 3 looks better IMO
Old Jan 20, 2016 | 11:43 AM
mcginnis22's Avatar
Yeah I'm kinda leaning towards the 3 plus my car is an auto. So I was thinking the 3 with a 3600 stall
Old Jan 20, 2016 | 11:56 AM
MonmouthCtyLS7's Avatar
get the 4 and a 4000 stall and don't look back . I haven't completely decided yet but the 4 in definitely in the running.
Old Jan 20, 2016 | 12:15 PM
Jtm2085's Avatar
I daily drove my 6 speed BTR stage 4 for quite some time
Old Jan 20, 2016 | 01:23 PM
mikes87ss's Avatar
I'm installing a BTR stage 3 right now in my 02
WS6.I'm also installing TSP stage 2.5 ls6 heads cut to 62cc.I have 6 speed with 390 gears.I can't wait till spring time.
Old Jan 20, 2016 | 01:42 PM
HCI2000SS's Avatar
Now that I think about it the 4 might have similar power down low as the 3 based on the specs. A few more degrees intake duration, but a tighter LSA with more advance. On paper it looks like the 4 could be just as good down low but with more top end pull
Old Jan 20, 2016 | 02:13 PM
BMR Sales2's Avatar
If you are wanting to keep the torque converter around a 3600 I would definitely stick with the stage 3 cam as it will have much better manners.
Here is a link to a pretty quick car I put together using the stage 4 cam. This car is more of drag car that gets driven on the street a little bit.
https://ls1tech.com/forums/10-second...-01-134-a.html
__________________
Glenn ***
Sales Tech
813.986.9302
Old Jan 20, 2016 | 02:44 PM
mcginnis22's Avatar
I may do the 4 with a 4000 stall. Since its not my daily driver. Does anyone have any dyno numbers or charts showing either cam?
Old Jan 20, 2016 | 03:56 PM
mcginnis22's Avatar
Or would the stage 4 be OK with a 3600 stall?
Old Jan 20, 2016 | 04:08 PM
ragtopz28's Avatar
^^This^^
I wanted the Stage IV but Brian said no go with my milled heads. I have the Stage III w/3600 (and a good tune) and it is fine. Made 402 unlocked and 420 locked (11.60 motor). Time in sig is on a 150 shot.
If your heads are stock I would do the IV w/4000 stall and have fun!!
Old Jan 21, 2016 | 10:43 PM
mcginnis22's Avatar
Is there a significant horsepower difference in these two cams?? My car will be mainly on the street. Don't know if I will ever make it to the track.
Old Jan 22, 2016 | 06:43 AM
I'm sure there's some. No better way to find out then calling BTR seeing its they're cam.
Old Jan 22, 2016 | 07:29 AM
HCI2000SS's Avatar
Between those 2 cams I bet there's not much more than a 5 hp difference....10 at most
Old Jan 22, 2016 | 07:44 AM
ezzlez28's Avatar
I have been running the stage 4 for 2 full years now. I have every bolt-on/supporting mod, and I have a manual. Through the 12-bolt, 3" steel driveshaft, 54lb clutch and 295/55/15 drag radials it made 471/406 to the wheels on a mustang dyno. I wanted a close to max effort type build and picked the stage 4 because of that. I can put it in 6th gear at 40mph (1000ish rpm) and putt around without any surging/bucking. But that is all in the tune. HP peaks at 6700.
As far as low end, the dyno started around 3600rpm, and the car was already making 370ft-lbs. Hits 400 ft lbs at 4500 and doesn't drop under 400 until 6000rpm. I couldn't be happier with how it turned out. It also really enjoys nitrous if you ever consider it down the road.
Old Jan 22, 2016 | 07:50 AM
Jtm2085's Avatar
471 is awesome! Do you have any track times? What heads are you using?
Old Jan 22, 2016 | 08:00 AM
ezzlez28's Avatar
Well I run 28" tires for the nitrous, so the N/A times are a bit skewed. Usually bogs pretty bad out of the hole. 11.7 @ 121 was the best N/A time. If I put 26" tire on it for a few real passes I imagine it would hit a 11.4 or so. 3650 raceweight.
Advanced Induction 226cc LS6 heads.
By Brett Foote | 2026-06-04 05:00:17
