Upgraded cam choice for my setup
I had a 10* overlap cam in my 418, and hated the light throttle/low RPM buck/surge. I now have 4* overlap cam with the same intake & exhaust duration. The car drives 10x better and has more mid range to top end power due to the earlier exhaust valve opening. And I'm changing to a 0* overlap cam with the same int & exh duration in a few weeks.
Russ Kemp
Russ Kemp
If I were in this situation I would leave well enough alone. It all comes down to what you want.
Think of a see-saw. On a simple note.. the bigger the cam, more overlap, may give you more power/top end, but at the cost of driveability/low end.
I've retuned cars that were dyno tuned and all had audible spark knock by the time the car was in 3rd or 4th gear @WOT. And they all had between 27*-28* spark timing. One car that was dyno tuned at a famous LS shop had 28* timing and had the knock sensors turned OFF!
Russ Kemp
Russ Kemp
Why the hell would you need those?
Russ Kemp
All the drivablity issues has to do with the tuner. Go to a tuner with a Mustang dyno so it can be loaded and drivability tuned, or find one that spends time actually tuning the car the right way, rather than just at wide open throttle on a dynojet for a number.
You will be MUCH happier if all you are concerned about is how the car drives IMO especially for a weekend warrior.
To be clear, I spent quite a bit of time explaining to the OP that I felt his engine made respectable power already and that he would lose driving manners with the cam I recommended. I explained to him thoroughly how the larger cam would affect the driving manners of the car, and what to expect in terms of performance gains.
I felt I conveyed to the OP that there is always a give and take relationship when it comes to smaller and larger camshafts and what to expect when installing a larger cam and removing a smaller cam.
