Morel 5315 install instructions
Old Jan 23, 2016 | 09:44 AM
mchicia1's Avatar
Default Morel 5315 install instructions
Looking for instructions on these, my box came from Co Speed totally bare. I'm not sure if I am supposed to clean and soak them em or just lube the wheels and put them in.
Old Jan 23, 2016 | 01:04 PM
vettenuts's Avatar
Blow them clean then roller the wheels submerged in oil to start breaking up the shipping grease. That's what I was instructed to do. When I installed, I coated with oil and coated the cam lobes with Redline Assembly Lube.
Old Jan 24, 2016 | 07:59 AM
vettenuts's Avatar
One other caution, I found the plunger in the Morel lifter moved very easy when they are new. So if measuring for a pushrod length you have to be very careful you don't depress the plunger while measuring.
Old Jan 24, 2016 | 09:19 AM
mchicia1's Avatar
Ok thanks vettenuts. I was told they are .025" lower than ls7s, so since I already know my LS7 zero lash, I will just buy .025" longer pushrods.
Old Jan 24, 2016 | 09:27 AM
mchicia1's Avatar
FYI found this.
http://johncalliesinc.com/pdf/Adjust...licLifters.pdf
Looks like pretty basic process, just wipe down and oil.
