Tap front of crank after broken bolt?
Also, I'm thinking of punning it for more insurance. Is that possible not using the stock pulley bolt size?
This is bad advice. NEVER use the crank bolt for this.
There's a bunch of inexpensive tools available: http://www.coloradospeed.com/tools-e...3-p-10976.html
A carbide drill, even a left hand one, if available, should do the trik.
But I'd say these bolts are heat treated all the way through, the center is as hard as the shank.
Staying centered is important, once the bit wanders into the threads, it's impossible to get it centered again.
I started by slipping a 12mm socket in the end of the crank and used it as a guide to start drilling my hole. I ran my 5/16" drill bit through the socket and drilled my first hole. Then stepped up to a 3/8", then a 7/16", followed by 1/2". At that point I took a 5/8" chisel and basically made a cross in the remains of the broken bolt. After that I finished drilling with my 35/64" bit. Once that punched through the bolt started coming out in chunks. I finished by by running my tap in and out quite a few times and threaded my new balancer bolt all the way in. To get this done I used solid cobalt steel bits, plenty of Tapfree cutting fluid, WD40, Kroil, and compressed air in a can.
