Straub Bushing Trunion Kits?
Old Jun 1, 2016 | 12:07 AM
  #361
roth2000's Avatar
Just wanted to say thanks for a great product. Finished my install the other day and aside from the assembly grease I also waited to add my engine oil till the very last moment. I poured some oil on the rockers just before installing the valve cover and coil packs, started it up and all was quiet. The combo of these trunnions, my lifter upgrade, and cammotion cam and you'd swear I was driving a minivan from the sound off the motor. The exhaust is the only thing that lets you know that somethings going on under the hood.
Old Jun 1, 2016 | 01:56 AM
  #362
Jontall's Avatar
Originally Posted by whatsa347
Bump, have a new set sitting in the other room, wondering the same thing.
I pulled apart three BTR trunnions with very low mileage. They are not shedding metal particles like my Comp trunnions, but the bearings are starting to cut grooves into the trunnion. (Less then 2,000 miles on them.)
Old Jun 1, 2016 | 06:42 AM
  #363
joyridin''s Avatar
My guess is the trunions are all made by the same company. BTR buys from Comp as well as Summit. They just rebrand them under their name. I know Summit does this al the time. The BTR cam is a Comp cam, so they probably have a relationship with each.
Old Jun 1, 2016 | 07:37 AM
  #364
Jontall's Avatar
I believe that the trunnions are far too soft when compared to the needle bearings. I don't understand why the trunnions are so poor in quality, but everyone that installs them are at risk of engine damage and it's a big problem. They should be using a very high quality Timken Steel for the trunnions.
Old Jun 1, 2016 | 09:25 AM
  #365
farmington's Avatar
So, are the Straub trunions the answer? I used bushed rockers with my old Mopars and had no issue but those were pressure fed oil. Will the Straubs survive longer than the Comp-BTR-Summit trunion replacements.
Old Jun 1, 2016 | 09:47 AM
  #366
Cstraub's Avatar
As I have stated, all of these are going to fail at some time. The advantage over the bushing is that when in failure mode it won't spit out needle bearings that could find it way to the oil pump and cause catastrophic failure.
The bronze being used is an impregnated alloy built for this type of application. I have 6 sets in some school cars and when the first one come down for inspection it will have had 25K hard miles put on it.
We have not reinvented the wheel here, we have gone with alloys that are proven in the field and used by OEM's. As you have pointed out shaft rockers with bronze alloys have been used for decades. Our design with the milled oil channel keeps constant oil fed to the bronze bushing. When the engine is not running or stored for a long period of time the oil is captured in the channel and will prevent any dry start ups.
We are over 2500 sets shipped on 4 continents now.
Old Jun 1, 2016 | 10:39 AM
  #367
Jontall's Avatar
The bronze bushings will never cut into the trunnions, so they should last a very long time.
Old Jun 1, 2016 | 12:02 PM
  #368
Redbull87's Avatar
I posted about my stock bolts needing to be slightly forced down through the trunion during initial install.Nobody seem to have caught that earlier on in this thread.That wasnt a major concern for me though so I moved on.I got bigger problems to fix now lol.
Old Jun 1, 2016 | 12:11 PM
  #369
mchicia1's Avatar
Assuming they were put into an OEM setup (stock cam etc), can we assume they would last as long as OEM?
Old Jun 1, 2016 | 01:16 PM
  #370
Cstraub's Avatar
I don't want to ASSuME anything. I do know experience is worth more than anything. Base on experience we used materials, heat treat, and finishes that have been used for decades. I have no reason to think that it won't. Again I want to stress, all of you have modified your cars beyond OEM limits. It is not a question of if it is going to fail but when. With the bushing trunnions in failure mode they will save you from catastrophic failure. Just like bushing lifters.
Old Jun 2, 2016 | 08:08 AM
  #371
mOtOrHeAd MiKe's Avatar
From: Saskatchewan, Canada - where arguing "DA" is for the slow and weak...
Big thanks to Chris for a taking a few minutes to answer my questions about the kit and helping place the order. Looking forward to running these in the wagon.
Old Jun 2, 2016 | 09:47 AM
  #372
Cstraub's Avatar
No thank you sir.
Old Jun 2, 2016 | 10:05 AM
  #373
The Alchemist's Avatar
UNDER PRESSURE MOD
Guys longevity for these is like asking how long valve springs last... it's one of those items that you should check maybe once a year, maybe every other year, it all depends on how hard you drive, and how many miles you put on your car.
Pull the valve covers, pull a rocker, pull a spring, do some basic checks every so often before it becomes a problem.
Old Jun 2, 2016 | 11:32 AM
  #374
Da Z06's Avatar
I replaced my Comp Cams trunnions with about 4200 miles @ .661 lift with Straub Technologies trunnions and bushings about 1000 miles ago. This is on my LS7.
The Comps showed some severe wear given the low mileage. Not happy with that.
One thing that may had an effect is that Comp's are lift limited to .660, so they were at the absolute lift limit.
The Straub kits was a straight up swap, no issues with installation, I utilized Royal Purple 5w30 during installation of the bushings, and engine assembly grease on the rocker mount, tip and valve tip. No squeak, noise or any other normality was noted.
Check out some pics.
Worn Comps
Straub Technologies Trunnions and Bronze bushings:
Video of the Sound:
http://vid36.photobucket.com/albums/...pslg4qcioy.mp4
Again, I got about 1000 miles on them now, I recommend!
Enjoy!
Old Jun 9, 2016 | 03:40 PM
  #375
chrisp250r's Avatar
Is a replacement bushing or rebuild kit available? Seems like a good kit, just wondering if it's serviceable or if you'll be buying another complete trunion kit when the bushings eventually wear out?
Old Jun 9, 2016 | 04:34 PM
  #376
Gray86hatch's Avatar
255 miles on my kit. Not a ounce of noise. Will be swapping the comp kit out of dad's this weekend. Should be able to hear the difference.
Tim
Old Jun 10, 2016 | 01:55 AM
  #377
Jontall's Avatar
Just replace everything when they wear out.
Old Jun 10, 2016 | 02:01 AM
  #378
Jontall's Avatar
Tim
They are very quiet and my car idles smoother too... There must have been so much wear on some of my Comp trunnions that it was causing a rough idle.
Old Jun 10, 2016 | 07:40 AM
  #379
Cstraub's Avatar
Replacement parts are available for our kits and they are available through all board sponsors.
Old Jun 21, 2016 | 05:40 PM
  #380
mchicia1's Avatar
BTRs out. Looked exactly like the Comp's in this thread. Some had mild wear, some had total destruction.
9k miles on them.
Straubs in, VT noticeably quieter. I just hope they last. If they can last 20k miles, I will be happy with that.
