Straub Bushing Trunion Kits?
Old 07-05-2016, 04:30 PM
  #421
joyridin''s Avatar
Originally Posted by Brian Tooley
We redesigned our trunnions to increase the amount of oiling to the bearings in January, which is why we've been out of these kits for most of this year. Unfortunately our supplier isn't able to run the new design in their grinding machine without extensive modifications.
We're in the market for a new manufacturer, even using new materials and new processes if needed. So if anyone knows someone, please send them our direction, or PM me their contact information.
Thanks
I have about 3 dozen or more shops. All in the Ohio region. Do you want a list of shops that can run these? I can even take the Summit version I have and they can send you a quote which should be very close to the final price minus your oiling additions.
I have a LOT of customers manufacturing aftermarket car parts these days. One customer is even making trunnions for a roller rocker manufacturer.
Contrary to what some people may suggest, these are simple to make with the right machine and material.
Old 07-05-2016, 05:20 PM
  #422
brobinson216's Avatar
Originally Posted by joyridin'
The grinding op will add nothing or maybe a few dollars to the cost. On top of that, I would not even grind it anymore. None of your automotive manufacturers grind. They all hard turn which will cut the cost even further. I have customers that manufacture bearings. They do not even get .03" runout on a 15" diameter bearing.
Besides, getting a 19Ra like the finish on the trunnions I had is hardly precision grinding especially for a bearing surface.
Sorry I missed this earlier, was rather enjoying the discussion.
To say the grinding operation will add little is a very generic statement. I've worked as a manufacturing/quality engineer for many years around precision gear grinding.
The Capital cost of purchase of said grinders can well exceed $1,000,000. Setup and supplies are super expensive. In most cases my company only runs those machines in lot quantities of > 500 pieces. The larger the run the better, simply put larger batch quantities yield better finished product as the machine warms to a nominal happy position.
Hard turning to burnish is a viable option, and would work well in the application with the correct bearing load specifications.
The product you had tested gives the story for that particular sample, but not a true analysis for the manufactured products in general.
I would agree that 19ra is not a desirable finish for precision grinding and looks more to me as a hard turned burnish as you discussed. 19ra is an acceptable finish for some applications such as oil seal diameters but not roller bearings which typically are manufactured to a superficial.
Back to materials: If I were to design a trunnion kit from scratch it would be 8620 through hardened to rc65-69.
Where the real cost of manufacturing comes to battle is quantities. If 100 per month, there's not a company domestic with a grinder that would touch that........not enough profits to profit.
Old 07-06-2016, 08:14 AM
  #423
joyridin''s Avatar
I have been working in the machining industry for 30 years now. You can get anything done these days for a lot less than people think. You again are assuming the parts have to be ground. I would not waste my time grinding them. As you stated, the cost of setting up the grinder is expensive, so in order to run a small quantity at a cheap rate, they are probably using some ancient POS machine. On top of that, it doesn't looks as though they are touching the surface where the trunnion mounts to the head, so I doubt anybody even knows if the bearing surfaces are parallel to the mating surface.
I wouldn't burnish them either, although that isn't a bad thought if you really needed to get a good finish. Hard turning will realistically give you a 8-12 Ra and you can hit the mating surface at the same time.
Things are really slow for a lot of companies these days. Finding somebody with a Turn-Mill (Integrex style) or a multi-axis lathe sitting there empty is pretty commonplace. As a matter of fact, I have a customer that just dropped $1.5 mil on a new grinder. It has been sitting now for 2 months empty.
Old 07-06-2016, 06:25 PM
  #424
Agreed
I'm contemplating just ordering a new set of shaft mounts. I'm confident the bushed kit is contaminating my LS2 after 3 separate oil changes. All of which have been consistent, cutting each ACDelco oil filter open and seeing micron bronze contamination.
Guess this is the perfect time to pull my stock 243's and put a set of TFS on. Evaluation of my bottom end is in order.
Old 07-06-2016, 07:14 PM
  #425
Tomhames's Avatar
Ouch.....
Old 07-07-2016, 03:08 PM
  #426
Jontall's Avatar
Originally Posted by brobinson216
Agreed
Is anyone else cutting their oil filter open to check for bronze particles? Can you post some pictures of the oil filter material?
Old 07-07-2016, 04:04 PM
  #427
427
427's Avatar
I have been cutting filters with no problems, but nothing over 4000miles yet. I took apart one set that were made by CHE, they looked great. I will be taking one of the Straub equipped rockers apart in the next few weeks and see how those are doing. I check size on all the rocker bodies I have done, all have been perfect except a small amount of LS7 rockers. I have one set of the Straub bushings in an aggressive Pro Touring racer with 200/500 springs, I won't see those until fall. Most I have running are normal-ish 150/420.
Kurt
Old 07-07-2016, 06:07 PM
  #428
Old 07-08-2016, 05:21 AM
  #429
Jontall's Avatar
I can see some particles, but maybe they are still breaking in. Maybe you should take one apart for inspection.
Old 07-08-2016, 07:17 AM
  #430
Tuskyz28's Avatar
Kurt
Kurt, What would do about the LS7 rocker arms or what do recommend for the LS7 headed motors ?
Old 07-08-2016, 09:10 AM
  #431
Cstraub's Avatar
We are approaching 3800 of these sold. Customers report MUCH quieter valve train. Oil changes on customers using LS engines for work that I have spoke too report nothing in oil filters. I have one customer that has an airboat fleet that see constant running for up to 16 hours a day from 3000 to 4800 rpm. Driving experience car service techs are monitoring all the school cars with the retro fit. Nothing in the filters reported.
Old 07-08-2016, 03:22 PM
  #432
dmracing's Avatar
I have 5 cars with them too. Nothing to report bad here either
Old 07-08-2016, 05:59 PM
  #433
Chris,
Lets get honest with people though........care to elaborate on the set you sent me in replacement?
The initial set I installed in my stock rockers contaminated my low mileage LS2 Corvette.
Care to provide results after teardown of the LVMS test pilot cars?
Old 07-09-2016, 08:59 AM
  #434
427
427's Avatar
I just hone the body if they are tight, but that is a rare so far. I use mostly LS3 style rockers, they have all fit without any modification.
Kurt
Old 07-09-2016, 10:59 AM
  #435
SSSTANG#1's Avatar
I replaced a set of comp with the Straub bushings and trunnions on LS7 rockers. The cam has ~.720 lift and engine sees just under 8k rpm.
Old 07-11-2016, 02:09 AM
  #436
39coupeute's Avatar
Happy with mine.They are quieter than the comps good value for money and easy install.
Old 07-11-2016, 04:27 AM
  #437
Quick Ranger's Avatar
Chris,
I'd like to hear more about this.
Old 07-14-2016, 02:18 AM
  #438
JCunningham's Avatar
anyone have a copy of the directions Straub is sending with the kits now. I know how to install them but would like to see what it says.
Old 07-14-2016, 10:43 AM
  #439
Cstraub's Avatar
email me and I will send you a copy. cstraub@straubtechnologies.com
Old 07-15-2016, 09:38 AM
  #440
FourG63 97GST's Avatar
who has these available in stock? was backordered last time I went through this thread
Quick Reply: Straub Bushing Trunion Kits?
