Straub Bushing Trunion Kits?
I found no metal debris when pressing bushings in like shown in the pictures a couple pages back, however i did find that if the bushings were pressed in too tightly they caused the trunion to get stuck and you could feel the trunion cutting into the bushing. A couple taps with a hammer on either side made them free again.
Ive been running this setup for about three and a half weeks now in 113 degree weather in california with rotella 15w40 and lunati gold dual valve springs and stock ls2 cam without a single issue. On first startup i had no issues with loud noises or squealing, after alot of WOT pulls tuning the engine ive had zero issues with these and would suggest them as an upgrade at this point in time.
Kurt
Thank you sir.
Thank you sir.
I suspect it's fine as the filter has been clean and I have more oil dripping on the trunnion than most, but the reduced pushrod flow had me over thinking it a bit. Can't wait to see them this winter!Kurt
Update: Having now run my new springs through two low RPM heat cycles, today I road tested and really spun up the LS6. Valve train has quieted quite a bit from the sewing machine noises it was making with the GM needle bearings (although those were entirely normal sounds). I'm just resting easier now. Glad I installed the trunnion kit. Glad I replaced the orig. yellow '03 springs.
I do have an experimental airplane company that will be testing an engine combination based on an LSX platform. Endurance testing for rpm between 1000 and 4200 rpm will be taking place in the next 60 days. Engine will be run at max rpm of 4200 rpm for 100 hours and taken apart. On this test customer will have OEM trunnions, Aftermarket Needle Trunnions, and Bushing Trunnions. Once the data has been collected from this test then it will be run for 250 hours non stop. Will put all 3 trunnion types on this build also.
I'll be waiting on your endurance results.
Thanks!
