Straub Bushing Trunion Kits?
Old Aug 15, 2016 | 06:59 AM
  #641
treybadd's Avatar
Originally Posted by feeder82
so I got to see one of the Straub kits up close, I friend bought one, what the hell is the deal with the brass bushings? I put a pair on the trunnion and they rock, do they compress when you press them into the rockers? I was kind of shocked at the slop in them.
How much rock? Your statement is vague.
Old Aug 15, 2016 | 09:25 PM
  #642
feeder82's Avatar
well, I don't have a way to measure, they rock just sliding them over the trunnion it seems excessive. Yes it is a vague description. I was wondering if someone would describe them as tight. No plans to install at this time, no reason to remove the comps at this time, going to wait till winter or signs of failure. thanks for the response I'll look into measuring the clearance when time for install comes
Old Aug 15, 2016 | 11:29 PM
  #643
Jontall's Avatar
Your Comp trunnions already failed and you just don't know it yet.
Old Aug 16, 2016 | 10:46 AM
  #644
Mercier's Avatar
They aren't extremely tight. Dry, they slide on and do have some movement to them. Remember, you need some clearance in there for oil!
It occurs to me that if they were "tight" they wouldn't get lubed and would burn up quickly.
Old Aug 16, 2016 | 10:50 AM
  #645
Tuskyz28's Avatar
It'll be nice if someone (professional engine builder) would offer to put the kit in correctly with lube/grease for you... instead of a average person doing them at home...
Old Aug 16, 2016 | 11:23 AM
  #646
Mercier's Avatar
Well I'm no professional and I take offense from anyone referring to me as such...but I can and do install these for folks. So far no whammies.
It's just not really a profitable business unless you are installing them, too. Damn day job gets in the way too much!
Old Aug 16, 2016 | 01:21 PM
  #647
Tuskyz28's Avatar
What oil should be use for assembly? Conventional oil, synthetic, break in oil or cam grease I call it ?
Old Aug 16, 2016 | 02:06 PM
  #648
whatsa347's Avatar
Yeah I'd like to know this too, about to order a set and going to purchase some cam lube at the same time since I'm installing everything at once.
Old Aug 16, 2016 | 02:27 PM
  #649
Tuskyz28's Avatar
Hmmm I been thinking about this while im on my way to work..... I'm thinking you couldn't go wrong with a good break in oil... since its high in zinc but I still want a answer to the question and a explanation.
Old Aug 16, 2016 | 03:53 PM
  #650
Jontall's Avatar
Assembly lube should be used, not oil. There is a packet of high pressure assembly lube in the box.
Old Aug 16, 2016 | 08:24 PM
  #651
slogo's Avatar
Doesn't CHE install these
Old Aug 17, 2016 | 07:03 AM
  #652
KCS's Avatar
KCS
Moderator
Yeah, CHE installs their brand of trunion. Most shops can install them as well since a vice or press is really all that's required to do the installs. It really isn't rocket surgery.
Old Aug 17, 2016 | 09:57 AM
  #653
Cstraub's Avatar
We put a packet of Driven Assembly lube in each kit sold.
Old Aug 17, 2016 | 10:01 AM
  #654
Cstraub's Avatar
The bushing clearance is much like bearing clearance, tight will lead to failure. The oil has to have room between the trunnion and the bushing. Maximum clearance is .008".
Old Aug 17, 2016 | 09:23 PM
  #655
FourG63 97GST's Avatar
whens the group buy
Old Aug 17, 2016 | 10:03 PM
  #656
redram2007's Avatar
So is everyone torquing the bolts to 29 ft lbs or is anyone using the stock torque specs of 22 ft lbs?
Old Aug 18, 2016 | 12:35 AM
  #657
Jontall's Avatar
22 ft lbs and anything more is just stretching the bolt.
Old Aug 18, 2016 | 01:43 AM
  #658
dmracing's Avatar
Originally Posted by 427
Factory LS7. It is running in a second gen Camaro Pro Touring type car, mostly auto X and road race, with a few street miles for fun.
Kurt
Did you have to do anything to the LS7 rocker to install the bushings
Old Aug 18, 2016 | 06:57 AM
  #659
427's Avatar
427
I did have to open up one rocker, it was under size by about .0004 on both sides. The engine started life as an early LS7, but it spit a lash cap and damaged one rocker about two years ago. The undersized rocker was the newer one bought from GM parts, the original rockers were all on size.
Kurt
Old Aug 18, 2016 | 11:37 AM
  #660
redram2007's Avatar
I wonder why they recommended 29 with their bolts? They are your normal socket cap bolts.
