Straub Bushing Trunion Kits?
These trunnion and bushing conversion kits require only the use of snap ring pliers and assembly lube or oil to assemble, and are made from the same materials that we have been using on our trunnion conversions since February of 2006. They are made from our proprietary bushing and valve guide material that we have been using for over 30 years. The bushings are designed to slip fit onto the trunnion and into the rocker and therefore do not need the use of special tools or a press. This design will increase the amount of usable wear surface, as the bushings will continue to rotate in the rockers and around the trunnion. Our oiling design is the same as it always has been, grooves that are machined in a spiral pattern around the bushing on the OD and ID. The trunnions are heat treated steel and precision ground to hold a +/-.0002” tolerance. The trunnions will accept both OEM and ARP bolts, as they always have, and we recommend a maximum lift of .670”. They were originally designed for Wegner Motorsports for use in the Spec Motor programs, and they have tested them to 9500 RPM without any failures.
We have kits in stock at this time, and pricing will be $199.95 plus shipping. Please feel free to contact me with any questions or concerns you may have and I will be happy to help.
Thank You!
Matt (805)499-8885 matt@cheprecision.com
Hi slogo, these are the same as the ones we do in house, except we made some changes to allow end users to easily do the conversion at home with out the downtime and costs associated with sending them in. We give you snap rings instead spirolocks, and we made the bushing to be installed without a press. Otherwise the materials and design are the same as they have always been.
Also what is the cost normally after december passes?
Should have my Straub bushings installed this weekend.
The after December price is ultimately up to the owners of the company, but I would assume it would go back to $260 shipped.
I installed my Straub kit tonight.
For my approach to the assembly I took advantage of our current cold snap of about -30*C (-20*F) and left the bushings and trunnion shafts outside for a day. This dropped the OD of the bushings from .813" down to about .810" (+/- .0005), which reduced the interference fit in the rocker bodies from about .003-5" down to about .001-.003". Some almost went together with hand pressure. Although I did used a Summit bench vice installation to ensure accurate installation.
Pretty much the easiest thing I have assembled in recent memory.
The way i see this newest design is that the chanel allows oil to make its way all the way around the bushing. The older designs has the cutout at the top and thus that small area is also a "void" Since all pressure is pushing the rocker off the stand its forced to the top of the bushing where the "void" is. This is effectively less surface area do to the void. and requires oil to make its way around the busing with no channels. The new design looks like the channel is in series with the oil flat feed on the top of the bushing. Oil feeds out the flat from the rocker and through the channel.
I personally like the swirl design I see in the CHE, but not that the bushing slips into the rocker body. I also dont see a large area for the oil to feed into those swirl channels like the straub has the large empty flat.
If you want known reliability just stick with the OEM trunnions (as delivered by GM) and a cam that suits their designed travel/load limitations. Otherwise, drop another $150 and get the newest design from Straub, and sell off the older version.
Nobody wants progress to stop... but unfortunately, without a large R&D budget, most aftermarket parts are "alpha or beta" examples and you are the R&D...
I have the 2nd design and I just retrofitted mine not even 3 months ago and they aren't installed on the heads yet. BUt Since this thread has been active there are 3 different versions. Improvements are good, but we would like to hear why from Chris Straub himself. If he found something out from those test vehicles he installed them on it should be passed down. Otherwise I see a product that has issues that he keeps working on to fix an issue. Otherwise I can't explain why he has had so many revisions so quickly. Id rather not install them if there is a known issue with them.
Clearly by the newest design he was having oiling issues otherwise he wouldnt have added the oil channel around the entire trunion.
Yes we all know this. you already sold me as I purchased your kit already and installed on my rockers. Have yet to install them on the motor which is being upgraded. I used your driven lube and engine assembly lube so make sure I get no wear on startup.
We are merely inquiring about your most recent new design. Clearly it has a positive affect otherwise you wouldnt have changed it, again. We want to know its purpose and if the 1st and 2nd designs are still fine even tho you have improved oil channeling on the 3rd design.
