LS1 Floating piston rod combo
http://www.summitracing.com/parts/ue...-std/overview/ im not sure what use shallow rings means though...
I'm guessing shallow rings means the rings grooves aren't deep so a ring with less radial width would be needed. I'm sure there's a PN that's recommended to be used if you do some more digging.
I don't know a lot about the LS engines, that's why I ask. But with a Ford motor that I'm more familiar with, floating pins would be a waste of money.
Rockauto does sell a floating pin "LS6" piston replacement, but they are stupid expensive.
