Building Replacement LS1. Need Cam Advice
Went to start it one morning and just went clunk. When it finally fired up it knocked like hell. Shut it down then went to start again and started just broke.
Pulled head, found #6 piston had cracked in half and rod snapped. Which also sent some **** into my ASA cam and put a hole in the block. So that engine was trashed.
Luckily I had already picked up a spare longblock that had like 100k.
My original mods were.
LS2 timing chain
GM ASA Cam
Yellow springs
Long tubes
Cat less Y Pipe
Hooker cat back
TSP hardened pushrods
3600 TCI SSF converter
3.73s
Various suspension mods
Supposedly made 380rwhp and around 370rwtq..
Here's the damage..
This is why I need cam advice. I don't think mine is fixable.
I miss my car...
Anyways. I plan to bring it back before June.
I have torn down the extra 01 LS1 that had 100k. It was clean as a whistle on the inside. Insanely well maintained. I swear I could eat off the inside!
I got a set of 243 heads from a CTSV w/ 40k.
My plan for my engine is:
243 heads w/ the yellow springs (Do I need special head gasket?)
ls2 timing chain
ls7 lifters
Melling 10295 oil pump
41-110 AC delco plugs
Any other suggestions?
Cam: ??? Fix my ASA, buy new ASA??
This car is not my daily driver but I want it reliable enough where it could be. I don't want a crazy cam. I want one that would be daily drivable. I don't want to loose any bottom end power or put all my power in top end. Then again I don't want to lose any potential power just by putting in a stock cam or ls6 cam. What do you all advise?
Trans:
I am swapping to a 2001 fbody T56. It had 170k so I am also trying to find a rebuild kit to order for it.
LS7 clutch
New GM slave
Speed bleeder
New GM pilot bearing
Pro 5.0
So camshaft advice or build advice? Also any input on what rebuild kit to order for the T56? It has 170k, it worked perfect but I plan to take it apart and replace most everything I can.
I don't want anything with high lift, I want to be able to still run my yellow springs.
That cam sounds like something I would be interested in. I just would hate to miss out on easy gains by using stock cam. Then again I don't want something that loses torque in the bottom end since that is mostly what I feel just driving around.
EDIT: maybe look into my old cam. TSP 224r. It was fairly mild, didn't lose tq, and sounded great. Specs were 224/224, .581 lift, 112 LSA
Lonnie
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
We can build the 224R cam on a low lift version (.550) and different base circle so that it will work with your LS6 springs and stock pushrods. Give us a call.Lonnie
Lonnie
I don't need an extreme cam, I just want to go ahead and get an aftermarket to squeeze out what I can while I'm assembling it. I have other play toys to make big power. I won't this thing to feel strong on the street but also be 100% reliable. I'd love for it to get decent economy with the 6speed as well as last a 100k miles or better.
