Fel Pro head gasket with notched heads
I know Fel-Pro makes a head gasket to use with the notched heads, 1041, .041 thickness. Does anyone know if they make one that is .051 or .054 thick? I want to have TEA work my 862 heads, but they wanted $200 to weld the notch, which seemed ridiculous.
If you get them welded then you can get these gaskets which are a lot cheaper. http://www.ws6project.com/user_stor/...-head-gaskets/
