5.3 push rod lenght help ??
im putting together a 5.3 for my car and want to make sure i get the right push rod the mods that would make effect on them are 706 heads milled .015, tsp 228r .600 .600, scorpion 1.7 roller rockers, BTR dual valve springs, stock thickness head gasket,..... the stock lenght push rods fill fine to me maybe just a hair tight ? i used my comp cams length checker and got 11 1/4 turns back to closed any help would be great ....what do i need to look for to make sure there going to be the perfect size ... rocker movement up and down ? should i feel the lifter preloading ? any help would be great thanks !!!
Below is a write-up I did some time back. Based on your numbers and assuming you are using the same adjustable pushrod, I get 7.3625" at zero lash. Using a 7.400" pushrod (note this isn't the stock length), you have 0.0375" preload. Not sure what lifters you are running so the desired preload needs to be determined prior to deciding if this preload is acceptable. I would also consider 11/32" OD pushrods if you buy new ones.
Here is my method:
Each turn of the pushrod is 0.050". When fully closed, it is 6.800". This is pushrod "gauge length" so you can't measure it directly as the pushrod length is actually based on the length between the ball ends where the ball end measures 0.140" in diameter. Assuming you are using stock rockers or a non-adjustable rocker.
1. Open the adjustable pushrod to the same length as your stock pushrods
2. Close it down two turns
3. Put your rocker rail on the head
4. Make sure you cylinder (typically #1) is at top dead center on the firing stroke so both valves would be closed
5. Put the pushrod in place on the intake valve and make sure it is in the lifter cup
6. Install the rocker and snug down the bolt (don't need to torque, just make sure it is snug)
7. Lift rocker tip up and down, if it "ticks" the pushrod is too short. If you can't easily move the rocker the pushrod is too long.
8. You can try and adjust the pushrod in place but my fingers are too fat so I end up pulling the rocker and adjusting the pushrod length. Go either shorter or longer 1/2 turn and try again.
9. You are trying to get to the point where the lifter doesn't "tick tick" with the pushrod in place nor is the rocker snug. When you get the pushrod length such that you just barely get rid of the "tick tick", you have found "zero lash".
10. When you have found zero lash, carefully remove the rocker and pushrod without rotating the pushrod.
11. Tighten the pushrod until it is fully closed counting the turns as you go.
To figure out your pushrod length you do the following. Let’s assume it took 10-1/2 turns to close the pushrod down to its shortest length after you reached zero lash. Each turn is 0.050".
Your length is then: 6.800" (fully closed length) + 10.5 X 0.050" (number of turns times the length change per turn) = pushrod length minus preload. So for this case:
6.800 +10.5 X 0.050 = 7.325"
This is the length you measured to zero lash without any lifter preload. Now let’s say you want to have 0.100" lifter preload, you add that to the measured number and you end up with 7.425" pushrods.
Now repeat for the exhaust valve to verify the length. If you have something like Yella Terra's, it is the same procedure but you must snug down the rocker pair rather than the single rocker.
__________________
Here is my method:
__________________
