Can someone help me identify these valve springs ?
Can someone help me identify which make/model springs these are ?
Length is 2.5in, OD is 1.3in, ID is 0.72in
Hoping to use these guys on a 6.0 with a nasty cam, something like an MS3 or equivalent meant to rev a bit higher. Any thoughts ? Are these definately LSx springs ?
They look like the Associated spring that everyone sells as the basic dual spring package for the LS - only way to kinda know is to run them over the spring tester.
Regardless, if they are the Associated spring, or simply of unknown origin you shouldn't use them with a really fast ramp cam anyways. Do it right and get the correct PAC springs for your application.
LS1Tech Premium Sponsor
Yeah, it's going to be a roll of the dice. You could have them checked for closed and open pressures, but I doubt a seller on CL is going to want to deal with having them tested first.
We do have new dual spring kits in stock and ready to ship, starting at $219.99! It's your choice of our PRC .650" or the PAC .660" dual spring. You can upgrade to titanium retainers for $30.
http://www.texas-speed.com/c-543-val...ring-kits.aspx
Sure, it's more than $100, but you get all new hardware with your new springs. Let us know if we can help!
Trevor
Texas Speed & Performance
Trevor
