Too much spring pressure?
Old Feb 20, 2016 | 04:25 PM
lsjeep52's Avatar
Default Too much spring pressure?
Ok, so I recently bought a set of LS1 heads off a buddy of mine SUPER cheap. They are CnCd with 210cc intake and 76cc exhaust. Valves are 2.02/1.575. Dual springs with 375lbs/in and max lift of .680. Closed seat pressure is 135lbs.
Im installing these on a stock bottom end 4.8, and I was gonna buy hardend pushrods along with SLP 1.85 rockers. I dont want to tear into the cam, and since I got the heads cheap, Id rather spend the extra on some push rods and rockers. My question is this too much seat pressure or can I install and not have to worry?
Old Feb 21, 2016 | 02:43 AM
ls1 1990 VN's Avatar
If your cam is standard, Then that is too much spring!
Old Feb 21, 2016 | 03:22 AM
03EBZ06's Avatar
Doesn't sound very high to me. 135/370 at 680 lift, no big deal. If they are shimmed, maybe you could remove a shim.
Old Feb 21, 2016 | 10:29 AM
lsjeep52's Avatar
If I remove the inner spring, it should come down to 105lbs on the seat. But is that enough for the 1.85 rockers or will they float?
Old Feb 22, 2016 | 07:31 AM
lsjeep52's Avatar
Bump for more suggestions?
Old Feb 22, 2016 | 03:28 PM
01ssreda4's Avatar
I run more pressure then that without issue.
Old Feb 23, 2016 | 06:32 AM
lsjeep52's Avatar
so stock cam with 1.85 rockers i should be fine?
Old Feb 23, 2016 | 06:42 AM
vettenuts's Avatar
Valve springs are fine and I would run them as is. I would investigate 11/32" pushrods, hardened pushrods are not stiffer they are made to run with guide plates. These will help control pushrod flex with the stiffer springs.
Old Feb 23, 2016 | 06:57 AM
lsjeep52's Avatar
do they make 11/32 pushrods for the 5/16 cup size of the lifters and rockers?
Old Feb 23, 2016 | 08:05 PM
Old Geezer's Avatar
Lightbulb Call..
Manton. They can make most any you need.
Old Feb 24, 2016 | 07:00 AM
vettenuts's Avatar
Yes, as stated above, Manton can make them. Do a check and make sure they will fit in your setup although I haven't seen anyone run into an issue yet with GM heads.
Old Feb 24, 2016 | 12:08 PM
lsjeep52's Avatar
Ok thanks guys, im gonna order the 11/32 dual tappered to 5/16 manta pushrods in 7.400. Hopefully i dont need a different length by changine out just the rockers, but ima get the length tool just in case. Im gonna run how the springs are first, but how will i know if they are too stiff?
Old Feb 24, 2016 | 02:13 PM
vettenuts's Avatar
Springs are fine. As for the pushrods, Manton uses overall length (OAL) not gauge length. Do if you use an adjustable pushrod to measure you can either directly measure OAL if you have a caliper long enough or add 0.017" to the gauge length measurement from the adjustable pushrod.
