how do you know if your push rods are to long?
started the motor for the first time, and i don't know if I'm being paranoid but i think I'm hearing a metallic sound from the motor. so this is what has prompted my question above.
running PRC Heads, Morel link lifters, Stock ls1 rocker arms, texas speed 228r cam, not sure about the push rod length.
im guessing either the rocker arms are making contact with the valve covers(no visible damage that i can see)
or
the valves are opening and making contact with pistons.
Car came with ms3 cam, and i swapped in the 228r, i didn't change the push rods..
so ls1 gurus, help out a noob, who wants to go fast-ish
--remove valve covers
--rotate engine to make sure I'm in the base circle.
--use an adjustable pushrod and digital caliper to find zero lash.
--add preload based on the lifter choice
--compare measurements and calculations to existing pushrods. If my numbers are shorter than the pushrods, then the pushrods are too long.
IMO, only way to know for sure.
"Too short" to me means there is lash
If your car is running fine, but you hear a metallic clacking, they could even be way too short.
Buy the $20 tool and measure, it's easy.
These are the pushrods I'm running
You need to buy the pushrod checker and 8" calipers and find the proper pushrod length at zero lash. Then find the preload range suggested for your lifters and add that number to your zero lash number. That is the pushrod length you need for the engine.
You really need to measure and figure it out...every combo is a little different it seems.
