LQ9 NOT on a tight budget
I picked up a 2005 LQ9 the other day and it'll be my first build or swap. The problem is every post, question, or article is on a tight budget. I don't want to go broke doing this but but what would be the best road to 500hp with no budget. Everyday driver.
To be clear the posts above would be talking about 500hp at the wheels.
If you want 700hp crank look at this: https://ls1tech.com/forums/generatio...ls3-heads.html
If you want 700hp at the wheels you better be looking at blowers/turbo/nitrous.
Our stage 1 will make 550-600rwhp no problem for you. If you send your stock ls3 castings in we will cnc port,valve job, surface and reassemble with our FRH spring kit for $1450. heads flow 380 intake and 260 exhaust
