LR4 Questions and Newbie
I have read articles that the LR4 is fairly durable, but does not have the torque a 5.3L does like the LM7. I do like the fact that the LR4 revs happily as we have one in a 2001 Silverado. This also makes me wonder if I can build this motor up to redline at 7000 RPM without breaking anything.
I'm not looking to do anything really crazy with this budget build, but would like to squeeze around 350-400HP at the crank out of it. I have been reading about cams, valve springs and heads that would assist in my goals, but really don't know what would be a good setup and an ideal pushrod length for any non-stock cam profiles.
As far as EFI goes, I am turning to Microsquirt for this.
My background is pretty much Porsche and Mercedes. The LS-swaps have hit many Porsche forums with some kick *** 944s out there pissing off the purists to high heaven. Somehow I think I am about to follow that same route.
This is the perfect board to learn about these engines too.Are there any recommendations for a budget 4.8L build to get me up to the HP numbers above and decent durability for track use?
That being said, if you can live with 6500RPM or lower redline, go with a 5.3 and a LS2 cam. 400 crank HP all day long with $60 valve springs and not much else that you wouldn't have been doing to the 4.8(I assume truck intake won't fit in the 944?). Factory-like reliability. Could do the same with the 4.8 and you would likely be more on the 350-360HP end of things with a few hundred more RPM but IDK if I would call it 7000.
Check this article out..great primer for what can be done with stock parts and a 5.3. Find some cheapie used LS1 intake valves and have the 5.3 heads cut out for a 2" valve and you'll gain a little on top.
http://www.hotrod.com/how-to/engine/1307-ls-cam-test-comparison/
It is slightly confusing the way they have it laid out but each test is that cam in the 5.3. It seems they are referring to a 6.0, etc. but what they mean is that cam originally came in a 6.0...the power numbers are that cam in the 5.3.
Now I want to build a damn Porsche.
You could just get the Summit trunion retrofit for under $150, the Chevy Performance Hot Cam kit (with springs) for $500 and see about getting LS1 valves put in your heads.
I'm no expert but that's probably all I'd do, put the redline at 6,500 RPM and see how she runs. If it costs more to put the valves in than to buy new heads, then put some #243 heads on. California labor costs, and all...
I cannot believe a 5.3 makes 400HP with just an LS2 cam. Amazing! If I that route which is by far the cheapest, what intake should I use as the truck one will not fit under the hood? LS6?
Now I kust have to find an LM7 for the dirt cheap price of the LR4 I am looking at ($400)
If you don't mind spending some $ on a cam but dont want to invest in expensive valve springs, call and tell them you want max effort with the LS6 valve springs. I predict you will end up with a better matched cam than the Hot Cam for the same price.
My $0.02.
I am not asking for any serious power increases as a stock 944 transmission can easily break when abused. 400 is now my set goal.
So to confirm, an LM7 with an LS2 cam, LS6 intake, LS6 springs is the best way to get to this goal? Man this is really exciting
if you can't use the truck intake, it takes some trickery to run the truck accessory drive. I don't recall what's involved with which combinations of intake / accessory drive because my LS lives in a truck - so everything fits. Do some more reading on what you need to buy / build / modify to make an LS6 intake live with your planned accessory setup.
Be sure to post pics / build thread when you build it
Real question will be fitment in front of the engine. Truck accessories sit out a little further from the block.
For the LS2 cam, you will need the LS2 front cover with sensor. Racetronix makes a cheap wiring extension that makes it plug right in. I think I mentioned before, that can be done at/under $100.
I am in the SF Bay Area. I am mulling over making this a smog legal build and having it BAR'd.
You'd have to start with a CARB approved engine block for passenger cars or an original, aluminum, LS1 / 2 / 3 / 6 / 7 block.
Alternately, buy a GM E-rod engine and stick with CARB parts on the outside - or make it an off-road racecar and skip the smog entirely.
Yes, though, you can use the stock ECU - it just needs to be tuned. As for "who"... Couldn't say. I had Painless tune an ECU and it came back without the "fan on" temp programmed. I'm not sure I would use them again but I might, purely for convenience.
Any other suggestions for valve spring choices if I run the LS2 cam?
On a side note, I have been scouring craigslist and even found a Gen IV L20 for cheap. Those have variable valve timing if I recall and 300HP out of the box. I would rather not deal with VVT in my application as I want to keep this swap as simple and straight forward as possible when it comes to tuning the EFI.
Searching the forums also led me to a thread where a guy did a turbo build (not sure if it was an LM7) in a 944. Man that car was sweet! I would love to do something like that later on, but the wallet is always the limit!
Looking at the hot rod mag article, it really looks like they are about the same on a 5.3 engine.
At 4500 RPM, the LS2 is down single digits in torque while the LS3 cam is up single digits. The spread from 4500 onward is even narrower. I'd run whichever you can get cheap and understand going into it that until 4,500 RPM you are actually losing power compared to stock.
Valve springs, I think a fresh set of GM blue springs would do fine but if you want to step up affordably(never a bad idea), an entry set of beehives like Comp 918s or PSI 1511s would do well. If you get to that point on your build and need some, I have a few sets around that are NASCAR track test takeoffs that were only run once. Make you a handsome deal on them but they're pretty affordable new as well.
Keep in mind that valve springs can be changed om the car in 30 mins.
