lifter noise and pre load
#46
Thanks Svede. I finally caught on. Did some digging this morning. This is my first time breaking down a LS motor. I'm old school. I'm used to the old GTO's. Own 16 of them. But I'm learning a lot from forums like this.
#47
Moderator
Received 1,853 Likes
the preload at 5 ft pounds is the same as 22 is the same as 45 ( don't do 45). Torque is bolt stretch, not preload. Do not count torque towards preload.
#49
In the most simplistic terms. Using an adjustable pushrod, I like the one with the lock nuts, adjust it to zero lash with the rocker arm torqued or at least tightened to remove all slop between it and the pedestal. Lifter should be on the base circle of the camshaft. Remove adjustable pushrod and measure over all length (end to end) with the dial caliper. Add desired preload to that measurement repeat for all lifters and order pushrods.
#51
Here is a lengthy thread that may help explain some of this: Lifter Preload Thread
#52
I tried to use a dial indicator the other day.The problem is I couldn't get the torq wrench in there to tighten the rocker arm. I put the indicator at the pushrod end of the rocker arm. set it to the same angle of the pushrod.The dial was too big to get the torque wrench in there. Are you guys using a small dial gauge or what? I got frustrated and ordered a comp pushrod length checker. Does somebody have any picks of this procedure.
#53
