Need some help
Old Mar 15, 2016 | 10:44 PM
Turbochrisss's Avatar
Default Need some help
Ok guys so I'm building a 4.8 ls Gen lll picked up a set of 243 heads need the exact arp head stud part#
Old Mar 15, 2016 | 11:32 PM
Paul Bell's Avatar
That's MISTER MODERATOR
As the 243 was the LS6 head, it would be 2003 and earlier so the ARP stud kit is 234-4110 with hex nuts, 234-4316 with 12 point nuts.
Old Mar 16, 2016 | 04:16 PM
alowerlevel's Avatar
Thought head bolt length was determined by the year of the block not the heads?
Old Mar 16, 2016 | 05:34 PM
TurboBuick6's Avatar
Yes that is correct. Gen3 have the two different lengths. Gen4 are all the same.
Old Mar 16, 2016 | 07:13 PM
Paul Bell's Avatar
Ahh yes, that's correct.
Turbochrisss, as you stated you have a Gen III block, the kit numbers above should still be correct.
The change in bolt length came in 2004 so you should confirm the block's year.
Old Mar 17, 2016 | 12:51 PM
gagliano7's Avatar
And 2004 had both styles depending when the engine was built. If all the big bolts are the same size you have the 2004 and up style.
