Replaced RMS, instantly leaked
Since I had the rear cover off as well when I changed mine I took some really fine emery cloth to the crank to clean up all the junk that was building up a groove where where the old seal ran. The new seal (in my case a GM seal), was a revised piece and didn't ride the same spot on the crank as the old one I removed.
I'd say if you didn't touch anything other than the seal that goes inside the rear cover against the crank and sealed the crank threads and didn't crack the pan then it almost has to be a defective seal. Either way you have to take it back apart. Once you get back inside the back of the block you might be able see where it all came from.
Absolutely! Bump it, and it'll crack.....
