Time for a top end change
Old Mar 22, 2016 | 11:46 AM
regency's Avatar
Default Time for a top end change
Ive gotten bored to the fact of what my package is but im really satisfied with how it has been running. Now i was sitting at 3980 race weight and will be sitting at 3780 in the next few weeks. On Nelson Performance dyno it went 389/329 and previous weight went 11.9x's @ 110.
Current top end is 228R-112, 243 heads (Home ported) milled .012 with .040 cometics, ported fast 90 with ls2 tb, pacesetter 1 3/4" headers.
Now i need to get a current time and trap with the 140# drop of rotational weight (140# drop in weight of wheels and tires) plus 55# of plain static weight. The rotational weight should give me a good bit.
I plan to go to 1 7/8" TSP headers, but i am not sure what heads and cam to go with. Ive long thought a out the MS3 or 4 and the Trickflow 220's.
Im kinda thinking of trying to pickup another .4 to .5 in time
Whats some thoughs on those cams and heads?
Old Mar 22, 2016 | 12:41 PM
Rise of the Phoenix's Avatar
Have you checked out the Speed Engineering 1 7/8" headers? They seem to be a great bang for the buck and the fitment is spot on. As far as heads go, you can't go wrong with a set of the TFS 220cc heads. If you get them from Brian Tooley, he can do some hand porting and put powdered metal guides in them so you can run your stock rockers. As far as the cam goes, I'd have Brian Tooley spec one out for you. One of his "off the shelf" cams may be just the ticket, or he may suggest something custom. Either way, you'd be in great hands with Brian specing out the heads/cam combo.
Are you planning on keeping the FAST 90 and LS2 TB setup?
Old Mar 22, 2016 | 01:10 PM
regency's Avatar
Brian didnt even cross my mind. I will get in contact with him.
As of now yes but if i could possibly find a decent priced tb i may would go ahead and swap to the 102. Everything 102 in the electronic style tb is high $$
Old Mar 22, 2016 | 03:27 PM
Public Enemy's Avatar
I have a BTR TFS 220 with BTR stage 4 cam and BTR ported fast 102mm. I also have speed engineering 1 7/8 with a custom 4 inch y pipe and 4 inch cutout. My shortblock is a stock ls2 with arp rod/main bolts.
With 4000 stall and proper rear end, tires and suspension, I ran 10.30 with over 130mph.. and I make over 500whp through a stalled auto.
On stock rockers, hydraulic cam.. I think this is max effort build with pump gas and very hard to make more power. Can't go wrong with Brian Tooley Racing.
Old Mar 22, 2016 | 03:30 PM
What compression are you running? That sounds like a damn stout setup.
Old Mar 22, 2016 | 05:01 PM
11.5:1.. the heads are 62cc and the gasket is 0.045" cometic gaskets..
The setup is well optimized.. but I still can't catch up with chrs1313
Hey made 522 whp on a
sbe ls1 and ran 9.89 @ 134mph
That is one of hell of a setup.. although he was 200lbs lighter and has 12 bolt. We trap the same. He had a tea tfs 215 head on his car.
Old Mar 22, 2016 | 05:14 PM
DavidBoren's Avatar
1.875" headers, Brian Tooley TFS220's, and a cam to match should give you an appreciable gain even without the weight reduction. I think that drop in rotational mass, combined with a BTR top end will be absolutely ****.
Old Mar 22, 2016 | 09:46 PM
regency's Avatar
Theres no doubt a pickup with around 500 rwhp would be fun! This package with my new bogart setup should get me close to the 11.0's if not all the way
Old Mar 22, 2016 | 09:52 PM
ls1itldo's Avatar
I would call TSP and see what they have to offer. I find it a lot better to buy from the guys who build the stuff you want vs a reseller like BTR. Since tsp grinds cams in house, cast their own aftermarket cylinder heads and actually tests their stuff them seem to have a good grasp on what makes power. I had a buddy who just got one of their camshafts and it is pretty badass. You can tell a difference just looking at them. Do your research!
Old Mar 23, 2016 | 01:00 AM
I tried both... TSP/PRC is great but BTR just made more power everywhere.
With that being said.. TSP 225 Heads are slightly cheaper. The BTR TFS 220 is around $2000. Not much difference.
Old Mar 23, 2016 | 01:17 AM
anthraxmm's Avatar
Lmao dude if you think btr is just a second hand shop maybe you should do some research.
Old Mar 23, 2016 | 08:03 AM
The Brian Tooley hand worked TFS 220cc heads with powdered metal guides is probably a little less than $2,000. At least it was when I was checking into them a couple years ago.
Another option would be to find a set of used AFR or TFS heads on the classified section on here. You can usually get a nice used set for around $1,600.
Old Mar 23, 2016 | 12:53 PM
ls1itldo's Avatar
I didnt say second hand... I think btr is just fine, everyone seems to like him. But what exactly does he manufacture there. What does he sell that isnt bought from another company.
Maybe you should do some research. Lol.
Again, the op can do what he wants just sharing my opinions like everyone else.
Old Mar 23, 2016 | 12:58 PM
Did you know he was the lead guy at TEA? I think he actually owned it if I'm not mistaken. I do know he was responsible for all the CNC work/programs there and was an iatrical part of the TFS heads. He manufactures his own springs and spring kits, and also his own trunion kit for stock rockers. Brian's springs and spring kits are next to none when it comes to quality.
Old Mar 23, 2016 | 02:27 PM
ls1itldo's Avatar
I have no clue what he did in the past. I will say that he has a great reputation, and I don't want anyone to think that I'm saying anything different. I was just stating information.
He may very well make his own spring kits, (again a lot of people swear by them) but it is pretty well know that comp cams, lunati, and maybe a few other use the exact same spring. Do they buy from BTR, maybe, I have no clue. But I doubt Lunati buys parts from BTR
Again, I really have nothing more to say, in fact I probably should have said nothing to begin with as I don't want to start a bunch of internet BS...
thanks
Old Mar 24, 2016 | 04:13 PM
regency's Avatar
Ive never dealt with BTR but seeing his rep on this site proves to me his setups are no doubt good. With that said i have a TSP 228R cam and I do love it so its really going to come down to who can get me a setup to reach my goal of 11.0 in a pickup with a stock bottom end LS1 without any FI or N2O
Old Mar 24, 2016 | 04:17 PM
What does the truck weigh? I think you're going to need a lot of compression and way more cam to get 11.0. It's also going to take some really good heads and a very good intake/TB setup.
Old Mar 24, 2016 | 08:23 PM
regency's Avatar
1st post is everything about it. Was 3980# now with bogarts and other weight removed itll be at 3780. Was running 11.9x's @ 110 and mid 1.5x - 60ft.
Im going to get a baseline with it setup now and see if its going to be a long shot or might be doable with the BTR topend
