Should I be worried?
Old Mar 22, 2016 | 02:33 PM
occhevelle's Avatar
Default Should I be worried?
I am doing a heads/cam install and when taking things apart I found one rod which was badly bent and gunky mud underneath the intake manifold on the alley cover and heads. I'm replacing all these items, however, I was worried if this is showing there is something wrong with the engine. It was running just fine with no problems that I knew about.
Thanks!
Old Mar 22, 2016 | 03:08 PM
Krab's Avatar
When you say rod, do you mean a push rod or a connecting rod? I'm assuming a pushrod. Have any pics?
Old Mar 22, 2016 | 03:54 PM
occhevelle's Avatar
Sorry, it's a bent pushrod
Old Mar 22, 2016 | 03:57 PM
thunderstruck507's Avatar
I've pulled a ton of slightly bent pushrods from stock motors. How bad was the bend?
EDIT: missed the picture, that's pretty bad...I would be concerned about the valve being bent as well if it's from an overrev
Old Mar 22, 2016 | 04:29 PM
occhevelle's Avatar
I'm putting new heads on with new valves so that should take care of a possible valve issue
Old Mar 22, 2016 | 06:28 PM
Krab's Avatar
That's pretty bad. You're replacing the pushrods and installing new heads/valves? You'll probably also see an eyebrow impression on that piston when you remove your heads. Honestly, I wouldn't worry about it since you're replacing these parts. Just chalk it up as a good reason not to miss a shift and move on with life.
Old Mar 23, 2016 | 07:13 AM
gagliano7's Avatar
And since you will have the heads off i would change lifters. You don't want to do that job twice if you can help it.
Old Mar 23, 2016 | 01:38 PM
agreed
might be worth looking into the Morel drop in lifters as well instead of the ls7s, they aren't much more and supposedly a little better build quality (but that could be incorrect)
