Oil Pressure
I have 21psi hot idle, ~40psi+ cruise, and 50+ WOT. From what I can tell most people have around 40psi hot and 65+ WOT-- This is why I think I have low oil pressure.
I have checked my pickup tube o-ring and it looks perfect. It had 400 miles on it, and looked brand new, but I still replaced it with a new GM one when I put it back together. While it was apart I replaced the cam gasket / retainer plate.
I have tried 5w-30 and 0w-40 Mobil 1, as well as mobil 1 filter and K&N Filter. NONE of this made a difference. Oil pressure remains the same.
Tonight I installed an aftermarket gauge. I installed the sending unit above the oil filter, and it pretty much mirrors the factory gauge.
So now I'm wondering what my next steps should be.. Run the car until it blows up? Replace the oil pump with a ported LS6 unit? Park the car and buy a 383 short block? Go in the corner and cry?
Not that it will make you fell better but GM service manual says at operating temperature minimum pressures.
6 psi @ 1000 rpm
18psi @ 2000 rpm
24psi @ 4000 rpm
As soon as I give it gas, the oil shoots up to 40+psi. I'm fine with driving it until the bottom end goes, but I don't want it to take out my new Mamo heads in the process!
I also have air bubbles on the dipstick, but I had them before I verified and replaced the o-ring as well. I've heard from many that the air bubble on dipstick isn't a great way to verify an o-ring issue. The rotating assembly can aerate the oil and cause bubbles.
Sorry if I sound paranoid guys, but the truth is I am paranoid!
I'm wondering if the Improved Racing crank scraper could help your aeration issue?
And no road racing, this is 100% street car. I just don't want to be afraid to beat the hell out of it.
