Rocker or lifter?
Old Apr 1, 2016 | 07:35 PM
Steve Cox's Avatar
Default Rocker or lifter?
Have a slight tick, Is there a easy way to tell if it is a rocker or lifter?
Old Apr 3, 2016 | 10:28 PM
Serioussn95's Avatar
first I would make sure its not an exhaust gasket. if not then try to locate the side or area, pop off the cover and then check for a loose rocker. also check the pushrods when on the base circle to see if there is any slack in them, that's a start.
Old Apr 3, 2016 | 10:31 PM
Steve Cox's Avatar
Thanks, Will check on it next weekend
