Extreme Budget Build
Old Apr 2, 2016 | 10:56 PM
thetransamkid's Avatar
Default Extreme Budget Build
Hello everyone!
I am very new to these forums so I will start this off by giving you guys some info. I am 18, still in high school, and I'm working on an $9.00/hour salary with an occasional $500-$1000 worth of roofing money. So like the title says, extreme budget.
My goal for this build is to be able to easily kill a newer Mustang or Camaro and with good daily driven ability.
This is the list I have built up so far.
-LS6 Intake.
-Craigslist or Ebay LT's.
-ON3 Performance 3" Catback
-Tsp 224r .600/.600 112 lsa camshaft and supporting valve train.
-ls7 lifters
-ls2 timing chain
-Ford Racing Green top 42lb injectors
-Underdrive pulley
-3.73's
-Nitto NT555 G2 275/40r17
I will be picking up a 2000 M6 Z28 with 116,xxx on the clock within the month. My future goals are some cheap ported 5.3 heads and maybe a bit of nitrous but other than that I plan to stay cam only for awhile. Any tips to point me in the right direction are greatly appreciated. Thanks for the help!
Old Apr 3, 2016 | 06:27 AM
ddnspider's Avatar
Don't automatically settle for an off the shelf cam, talk to a few vendors about your goals and mods to be and then see what cam suits you best. And go speed engineering 1-7/8 headers
Old Apr 3, 2016 | 07:35 AM
Jtm2085's Avatar
I would definitely do some more research on a camshaft. The 224 is really small. Keep an eye out in the parts classifieds here. You can pick up all kinds of deals if your patient
Old Apr 3, 2016 | 11:42 AM
Darth_V8r's Avatar
Moderator
Save money on the cat back. Do cutouts instead. They you've got restriction free exhaust when you need it
Old Apr 3, 2016 | 12:34 PM
69gto96z's Avatar
Go larger on the cam, eBay Potz ported throttle body, and Speed Engineering 1 7/8s longtubes. To swap the lifters you will have to pull the heads. If you're lifters are in good shape, I would leave them until you are ready to pull the heads. If you feel you need to swap the lifters, I would hit up Brian Tooley for some Morel 5315s over the LS7 any day. Cam only plus a NX proton kit (very budget minded nitrous kit) on the 150 pills will get you in the range of 550rwhp safely on a stock bottom end.
Old Apr 3, 2016 | 04:09 PM
RollinSScamaro's Avatar
+1 to everything here.. could always go with a 228 cam..
Old Apr 3, 2016 | 05:04 PM
King23's Avatar
I would look at some 4.10 gears as well if it's a 6 speed it will help just be easy on that 10 bolt.
