LR4 Head Casting Numbers
Old Apr 17, 2016 | 11:24 AM
63Willys's Avatar
Default LR4 Head Casting Numbers
Hey all, I'm new to the forum so apologies if this is the wrong thread for my questions.
I have an LR4, or so I think, that I am using for a Jeep LJ project. I found some dimple numbers on the heads that I can't seem to identify. Can anyone help?
Block casting number 12567392 - 2005 era LR4 block, correct?
passengar side - 711019137848925 (rear of the head)
passengar side - 7110T3744776 (front of the head)
driver side - 71101910915992 (front of head)
driver side - 7110T3754776 (rear of head)
Thanks,
Lane
Old Apr 17, 2016 | 04:10 PM
JoeNova's Avatar
Restricted User
The head casting numbers are just 3 numbers cast into the corners of the heads, facing up, right next to the valve covers.
Old Apr 17, 2016 | 05:07 PM
63Willys's Avatar
Thanks for the tip, I'll check there. Any idea what these other numbers are?
Old Apr 18, 2016 | 08:42 AM
gagliano7's Avatar
706 or 862.
Old Apr 18, 2016 | 10:02 AM
63Willys's Avatar
Originally Posted by gagliano7
706 or 862.
I have teh 862, thanks.
Any idea what the other numbers are/mean? Can't seem to find anything in the Googles
Old Apr 18, 2016 | 10:36 AM
JoeNova's Avatar
Restricted User
Once you have the 3 digit casting number, the other numbers are basically meaningless. They might indicate origin, location, date, etc, but the 3 digit number is what you need to pay attention to.
Old Apr 19, 2016 | 10:14 PM
63Willys's Avatar
You're right but I was kinda hopin for some deeper info if they meant something.
Old Apr 19, 2016 | 10:59 PM
JoeNova's Avatar
Restricted User
I guess I'm confused on the curiosity. An 862 head is going to be 99.99% identical to another 862 head even if all of the dimple-punched numbers are completely different, making them almost irrelevant.
Pay attention to what casting the head came out of, not what someone stamped into the side of it afterwards.
Btw, they stamped numbers are usually a combination of the GM part number and the serial number that contained date codes for the heads.
