ls1 cam for DD
Old Apr 19, 2016 | 03:32 PM
LS99TransAm's Avatar
Default ls1 cam for DD
Ive picked a few different cams.. but cant choose which one. car is an auto, plan to run around a 3000 stall, car will be every other day DD. will go to the track a few times a year. will be getting P&P 243s, LT headers, 90mm intake, 3.42 gears. anybody use any of these cams before? and what kinda results did you get? or do you have any other recommendations? thanks.
1. comp xer273hr
lift-581/588
@.050 224/230 lsa-114
2. comp xer281hr
lift-595/598
@.050 232/234 lsa-112
3. howards 190375-15
lift-.609/604
@.050 224/230 lsa-115
4. btr n/a stage 2
lift-614/576
@.050 227/234 lsa-113+2
Old Apr 19, 2016 | 03:42 PM
thunderstruck507's Avatar
I would avoid the Comps.
With your conservative stall choice I would look at this:
http://store.cammotion.com/the-titan3-1
Maybe make the jump to the Titan 4 227/232 since you will get some extra compression from the 243s.
If it just has to be one from your list the BTR cam would be my pick but have him get it ground through Cam Motion instead of Comp.
Old Apr 19, 2016 | 05:12 PM
whatsa347's Avatar
Streetsweeper HT, I'd get at least at 3600 stall as well.
Old Apr 19, 2016 | 09:48 PM
mjs1012's Avatar
This is my combo and although I don't daily the car, I easily could.
Old Apr 19, 2016 | 10:01 PM
ls1itldo's Avatar
Look at the TSP torquer 2. That cam was awesome as a daily and makes excellent power. They also have the best lobes of any manufactures out there IMO.
www.texas-speed.com
Old Apr 19, 2016 | 10:08 PM
JakeFusion's Avatar
Super Hulk Smash
BTR Stage 2 is what I would go with. Hands down.
The lobe design there is very good and Comp has corrected their past issues. I feel confident in what they are doing. So much so, that I'm now using a BTR designed cam.
Old Apr 20, 2016 | 10:30 AM
speedtigger's Avatar
Old School Heavy
1. comp xer273hr
lift-581/588
2. comp xer281hr
lift-595/598
lift-.609/604
4. btr n/a stage 2
lift-614/576
For your stall and gear, you could use the Titan 3 or the Titan 2. Both will run hard. The Titan 2 will idle a little smoother and have slightly better daily manners. Can't loose with either in your application.
No arguments there on Brian Tooley Racing being a superb vendor. I'm running several of his parts on my car and have sent a lot of local guys to him for the same parts.
But on the other side of the coin there is nothing Comp could do which would regain my business. The issue not being simply the subpar product they had for some time but the customer service the people who got bit by it (myself included) received. For the sake of not cluttering OP's thread I will leave it at that.
Good to hear they got it fixed though.
Old Apr 20, 2016 | 12:54 PM
TXZ28LS1's Avatar
OP,
Id go bigger stall...
