Cam timing sprocket help
Again though..why LY6 cam? I think that cam itself is a waste of time, regardless of timing gear issues. I searched and searched for specs on that cam a few times and can't find anything. It IS VVT though. Not sure what that changes, either..but I plan on just deleting VVT on the engine I have on the stand. I have a LS1 cam that came from an engine that could have had more oil changes(so non-wear surfaces are dirty) BUT doesn't appear to have abnormal wear. $20+ shipping and you can have it. It's a three bolt cam that the 1x LS2 cam gear should bolt right to($30 for a whole Cloyes set for this with chain at O'Reilley Auto Parts). Problem solved and I am willing to bet it is a much better cam for a 5.3. Even though I have no clue what the LY6 cam is, most 6.0 cams are pretty tame until you get into LS2 and those fetch a little more $$.
See here what Hot Rod did with a 5.3 and LS1 cam...yours probably has better heads, too. They were up 63 HP and 51Lb-ft. @ 6500RPM.
http://www.hotrod.com/how-to/engine/...st-comparison/
Current setup is aluminum 5.3, flat top Pistons, rebuilt 317 heads, ls6 cam, Vic Jr intake with the fitech 1200hp efi. I haven't fired it up yet as I'm still working out a few things on the ls swap in my s10. Just wanted to do the cam swap before everything goes in.
EDIT: maybe not so bad as it's a fluid..all VVT cams I guess by definition are running full of oil.
