broke a comp cams double spring
Old Apr 24, 2016 | 11:28 AM
rajbcpa's Avatar
Default broke a comp cams double spring
...this one was in the car +10 years, so I can't complain.
cam is a mild street - 220/220
...anyway I ripped the head off to check for bent valve, piston damage.... all checked out ok....
Old Apr 24, 2016 | 01:19 PM
99monguse's Avatar
What kind of noise did you hear that made you think the spring was broken
Old Apr 24, 2016 | 01:29 PM
rajbcpa's Avatar
noise was a valve train crunching noise, I believe... spring had about 50K miles... ...very lucky no damage to pistons/valves,,,,
Old Apr 24, 2016 | 01:30 PM
rajbcpa's Avatar
...I was able to buy a single replacement spring from comp cams....
Old Apr 24, 2016 | 01:35 PM
99 Black Bird T/A's Avatar
Sounds like a good catch.
Given the other valve springs have a similar amount of wear and use on them, have you considered replacing all of the valve springs while your into the motor?
Old Apr 24, 2016 | 02:46 PM
rajbcpa's Avatar
...yeah, I thought a bunch about doing all new 16 springs.....
....did not do this because the cam is not too big..... hoping the other old springs do not start popping like corn???
Old Apr 24, 2016 | 08:09 PM
Taxman20's Avatar
I would change all the springs. Doesn't matter what the lift is, if one broke the rest may not be too far behind. Spring sets are pretty cheap. 200.00 for springs or a new engine rebuild when you aren't so lucky when the next one breaks.
Old Apr 24, 2016 | 08:13 PM
LLLosingit's Avatar
Originally Posted by Taxman20
Spring sets are pretty cheap. 2000.00 for springs or a new engine rebuild when you aren't so lucky when the next one breaks.
Those are some expensive springs lol... You might have added an extra zero there
Old Apr 24, 2016 | 08:30 PM
Taxman20's Avatar
What are you saying? You must be on the pot.
Pay no attention to mentions of edits. hehe Its been a long weekend.
Old Apr 24, 2016 | 08:52 PM
kinglt-1's Avatar
I would change all the springs not just 1. BTR platinums
Old Apr 25, 2016 | 12:15 AM
LLLosingit's Avatar
What edits?....What are you talking about?... You must be drunk
As far as the OP is concerned take peoples advice and change all the springs, If one broke already you're asking for trouble by not changing them all.
Old Apr 25, 2016 | 07:22 AM
Darth_V8r's Avatar
Moderator
Yes. Spring life is limited by fatigue cycles. They all went in at the same time and have the same number of cycles. You should changed them all. You were luckier than many. You got a warning shot before the grenade. Don't let the grenade detonate
