Lq4 with 799 milled
Ok guys i pulled the trigger on my build it consists of a lq4 stock bottom end ima be running gm mls head gaskets with 799s milled .30 with 228/232 cam with a NNBS intake what are yalls thoughts on it and i would like to know around what CR this build will be at. Also what spec of a head gasket will i need .51 or .41
LS1Tech Premium Sponsor
Stock LS2/6.0 will work the best esp with your milling
Gm MLS 6.0l head gasket set (pair)
there you go!
there you go!
