Leak from the back of LS9 head gasket??
Well it could be that the particular scenario that puts oil in the ports doesn't happen at/near idle. Could only happen when you slam the throttle closed after a WOT run when vacuum spikes. IDK if that is it at all, but my message is that in 30-40 seconds you may not have tested all common operating situations.
