Sanding mating surfaces
I'm not here to **** on anyone's ideas or skills. I just have a different view and more than a few years of practical machining and metrology experience.
If the machine shop says it's flat and hasn't been decked, it's probably got a good enough surface finish to run a stock type MLS gasket on. You could verify with a surface finish tester. Lastly, discoloration does not mean poor surface finish.
Here’s another great video what shows why the roloc shouldn't be used… even the soft rubber kind.
Always acceptations to the rule and a lot depends on the application.
The light roloc disc used sparingly on an iron surface isn’t going to hurt much and will clean it up fast. If I were putting together an mild NA build I wouldn’t think twice about his method. In the right experienced hands you’ll see very little distortion with a roloc on an iron deck surface. I wouldn’t use one for alum… but people do all the time.
I like to use a block that’s about twice as large as the surface. I order flat alum 3/4" - ½” thick to use as a sanding block. The sanding blocks pictured above aren’t very true/flat when dealing with deck/head surfaces.
Clean it up with a razor, hit it with 200g then 400g. LS9 gasket. Tested this method many times without a head gasket leak to date up to 30+lbs of boost on 10:1 LS engines.
This DIY surface job is holding strong. Currently running 8.70 1/4 miles around 160. Using the sanding block above, final pass using 400g. (wet sanded)
With the acception being the new alum LS blocks. (NA blocks) Seems like GM decided the head gaskets were good enough to seal with poorly finished decks and heads. The gen4 alum motors I’ve seen have all had very poor deck/head surfaces. My LC9 leaked. I block sanded the deck/heads down to 400g with no luck. They leaked half way through the season.
Heres the great OEM finish…
Even the heads suck…
Subaru Head Gasket Preparation - YouTube
I've used Roloc's for years and they even have a special pad specifically for doing gasket material on blocks. If you can get all the old gasket material off without using any type of abrasive, have at it, but that usually isn't the case.
Do you actually tell a customer they can save money if you clean the surfaces
the sloppy, hurry up and don't care if it seals or not way? I have never known any person with even an ounce of decency even think of that.
Next time you use a roloc disk put a quality straight edge over surface and
look at it good, get some light behind it, then ask yourself if you would do that to your own block, that you wanted to live.
I was at a GM facility when we tested a roughing cutter on the new LT1 block. We got a 19-20Ra right off the bat. We kept increasing the feed until we got it higher. The finish on the roughing operation wasn't that critical but flatness was.
We are not talking about using sanding disks on a Roloc, we are talking about using a very fine scotch-brite pad. If you distort the surface or gouge it that bad with that pad, you have a LOT more problems to worry about than the finish or flatness.
Let's get this straight. I don't think you even read what I wrote. If you did , you didn't comprehend it well. I suggest to rereading it. I clearly stated I use a straight edge to check tolerances. Obviously I didn't just set a ruler on the deck of the block in the dark & said that looks good to me. I know the difference between a ruler & straight edge. Along with the proper procedures to use a straight edge. I'm not "selling" the Roloc disc method. Every one of these cases were cast iron blocks in side work vehicles done outside of a shop. So these clients often are family, close friends or friends of friends. I advise to do the proper method 1st EVERY time. The proper method works 90% of the time. But every now & then I get the joy of a neglected vehicle.
That has crazy amounts of build up & what not. I can't tell how many times people use tabs, blue devil, stop leak to "fix" coolant system failures.(big NO NO)On these often I find myself pulling teeth just to get the owners to the point of resurfacing the head. I refuse the work on the vehicle if they don't go past this point. I'll NEVER just to blindly slap a head gasket on. Some of the customers I deal with are tight on $. So they want/demand the middle ground route to just get them back on the road. Even if that means temporarily. I don't prefer incorrect methods. If the customer is willing to gamble I'll often play to an extent. The last time I did the Roloc bristle method was on a 5.3 work truck. At the time of repair it had about 140k on the odo. It's still rocking the same head gaskets 4+years later with 300k+miles now on the odo. The heads were resurfaced but the block wasn't. This truck is driven from San Antonio too the midland area on a bi-weekly basis. So it's clearly working. If you take 1 thing from this particular post ALWAYS DO IT THE CORRECT WAY.Let's summarize. I PREFER the proper method. Have I done head gaskets another way besides the proper method? Reluctantly yes.
Below is the disc I've used in the improper/less desired method. Figured I'd clear up the confusion about my posts.
My first job in my Dad's shop was cleaning a cylinder block mating surface.
