LM7 build
Old Jul 1, 2016 | 12:15 PM
JoeNova's Avatar
Restricted User
Like I said before, I got the non-pro and the AEM UEGO from Scoggin Dickey for less than $600 to my door.
Old Jul 1, 2016 | 05:55 PM
LSXjohnny81's Avatar
Default Getting started
Hi my name is John and I'm new to the site and building engines. I don't no if this is the right thread for this question but I can't figure out the site lol. I have a 5.3 out of a 04 avalanche and im try'n to figure out what it is ? Is it a lm7 5.3 or the other style? I have the vin code. But the guy told me it could be a t or z 8th digit but here the vin if somebody could shoot me in the right direction.
3GNEC12T14G330264..... ? THX
Old Jul 1, 2016 | 06:13 PM
rik881's Avatar
Wrong topic indeed, you might want to post your own. AS far as i know you have a LM7 indeed.
Old Jul 1, 2016 | 06:29 PM
rik881's Avatar
I'm going to mail them. If i'd find a second hand Hptuners kit i could just buy credits it seems. Not sure how mich for the credits though.
Old Jul 1, 2016 | 06:38 PM
Mercier's Avatar
Credits cost about $25/ea. and you need 2 per vehicle last time I checked.
Old Jul 1, 2016 | 06:42 PM
rik881's Avatar
Now we are talking.
Old Jul 1, 2016 | 11:49 PM
rik881's Avatar
How is it that when i read about salvage engines on a dyno making +/-340 hp stock or with only headers and factory software? I thought they were rated 285hp?
Old Jul 2, 2016 | 08:32 AM
JoeNova's Avatar
Restricted User
Because most of the guys using the engine dynos are basically using gross HP ratings like they did in the 60s.
Dyno with no accessories, electric water pump, etc. They are rated at 285 net, which includes all accessories and emissions equip, plus water pump, etc.
Old Jul 2, 2016 | 12:19 PM
rik881's Avatar
That explains a lot. I never knew those accessories ate so much power.
Old Jul 5, 2016 | 10:27 AM
MaroonMonsterLS1's Avatar
You can log fuel pressure with the basic too. Just use the AC port and a FP sensor with the same output signal. You can even install a switch in the line so you can log fuel pressure when you want (AC will probably be off anyway) then when you don't, switch it so the AC wiring is as normal and have your AC. It's a win-win. Just have to set up the PID like you do with the EGR wideband.
