Installing rockers
Old Jun 21, 2016 | 05:00 PM
Majestic9C1's Avatar
Default Installing rockers
I'm looking to install some rockers and I was curious if there is anything special I need to do..
I'm just replacing my stock rockers with another set of stock rockers that has the trunion upgrade done to them already...
no fancy shmancy billet jewels or anything of that sort.
Old Jun 21, 2016 | 09:53 PM
unit's Avatar
There are a number of ways to do it:
You can just unbolt them one at a time and reinstall the new one. That's probably not the best because there is a possibility that you can strip the threads on a rocker bolt when a valve is wide open and there is a lot of tension on the bolt.
Another way is to use EO/IC method. When the exhaust valve starts to open, the intake valve is closed. The lifter is on the base circle of the cam at that point and you can do the intake rocker. Turn the engine by hand and watch for the intake valve to open. At that point you can do the exhaust valve.
A third method is to watch for the intake valve to close and then turn the engine about a third of a revolution more. Both valves will be closed and you can do both intake and exhaust on that cylinder. LS1 firing order is 1, 8, 7, 2, 6, 5, 4, 3. If you start at #1, turn the engine 90 degrees and do #8. Then turn the engine another 90 degrees and do # 7. Keep up in firing order until you've done all eight cylinders.
You don't have to be exact with this because all you're doing is swapping out rocker arms. If a valve is part way open, there is little chance of damaging anything.
Old Jun 22, 2016 | 03:09 AM
AgFormula02's Avatar
Agreed with post above, if replacing with stock rockers, just bolt them down to proper tq
Old Jun 22, 2016 | 05:51 AM
vettenuts's Avatar
Or you could follow the GM service manual:
Old Jun 22, 2016 | 01:13 PM
roth2000's Avatar
^ this is exactly how I did mine. I rotated the crank again and checked them all for torque after the first round.
Old Jun 22, 2016 | 01:45 PM
AutomagicLS1's Avatar
thread sealant on the bolts if aftermarket heads (to keep oil from getting in the runners) and torque to 22 ft lbs.
Old Jun 22, 2016 | 02:02 PM
stock 241 heads on it now..
thanks for the replies..
Old Jun 22, 2016 | 02:28 PM
black02-z28's Avatar
Just tightening them down will prob work, but way better to follow the service manual.
Old Jun 22, 2016 | 03:28 PM
dailydriver's Avatar
Besides the stripped thread possibilities, are you guaranteed to have a noisy valvetrain doing the above, since everyone on here is always ranting and raving about "proper lash" and such (and claiming that it WILL BE noisy if the GM manual procedure is not follwed to the letter), even on a 200% pure stock/stock length pushrod, valvetrain??!
