LS3 heads on LM7?
Old Jun 23, 2016 | 03:59 PM
ek9beezler's Avatar
Default LS3 heads on LM7?
I'm sure this has been asked before but after searching I couldn't find a definitive answer. I'm building a twin turbo LM7 and was looking at doing valvetrain upgrades. Instead of porting the LM7 heads, putting in new springs, retainers etc. I was thinking of just buying some of the Chevrolet performance heads since they come complete and ready to rock. PN# Chevrolet Performance 88958758
My question is the specs say they need a minimum 4.0 bore but the stock bore is 3.78 and this trucks. Will this work or will I run into problems?
Old Jun 23, 2016 | 04:00 PM
KCS's Avatar
KCS
Moderator
It won't work.
Old Jun 23, 2016 | 04:11 PM
ek9beezler's Avatar
That's a bummer. So my option would be to CNC the LM7 heads and upgrade the valvetrain?
Old Jun 24, 2016 | 07:07 AM
KCS's Avatar
KCS
Moderator
That's one option, yes.
Old Jun 24, 2016 | 08:29 AM
samckitt's Avatar
I keep hearing about small bore LS3 heads. I don't know if they are aftermarket, or GM. Might look into that. Or put a 4.8L crank in a 6.0L block. Will give you a short stroke screamer. Or just use a 6.0L.
Looks like the small bore LS3 heads may be GM. Prob wont bolt to regular heads since they have 6 bolt configuration.
Old Jun 24, 2016 | 08:45 AM
KCS's Avatar
KCS
Moderator
The small bore stuff still requires a 3.90" bore. At 3.780" bore, the 4.8L/5.3L engines are pretty much stuck with cathedral heads unless you punch the block out to 3.90".
Old Jun 24, 2016 | 08:57 AM
redtan's Avatar
Old Jun 24, 2016 | 09:55 AM
JoeNova's Avatar
Restricted User
Hahahah.
If you're building a stock bottom end car, its pointless to upgrade heads.
