Single beehive 9/18s
Retainers effect valve closing time. Heavier retainers effect open/close pressures of the spring itself. When the springs are tested for pressure, it is without a retainer. They also add momentum during the open/close events, so lighter retainers help with harmonics and resonance. The same goes with the actual valves. Their entire mass is being shifted by the valvetrain, therefore their weight is a big factor. The heavier the valve, the more it also effects the springs open and close pressures.
The spring itself is supported by the head. Its true that the weight of the spring can effect opening/closing time, but since its entire mass is not supported by the valvetrain, it doesn't play nearly as big of a role.
I got everything I needed from Brian Tooley...including his ridiculously light titanium beehive retainers!
Here's a photo showing old vs. new
I think it worth noting that TSP literally states that the V2 is beehive or dual friendly and the V4, with a more aggressive lobe design, requires duals. So nothing inherently wrong with running duals with the V2 but if you can get away with a lighter spring with lower pressure, you have more power potential. How much? I don't know. Will that potential be realized? I also don't know. Is it worth giving up the safety of duals? Also up for debate.
I'm personally looking for relatively high RPMs with a stock short block out of this next build and so even spring weight(duals weigh more) has been on my mind.
For reference..open pressure is not that different but seat pressure is very different %-wise:
PSI 1511:
Desc. Beehive
O.D. 1.290"
I.D. Outer .630"
I.D. Middle N/A
I.D. Inner N/A
Seat Pressure 130lbs@1.800 "
Open Pressure 370lbs@1.175 "
Rate Lb./In. 384
Retainer Step .000"
Max Lift .625"
Coil Blind 1.100"
BTR Platinum Dual:
155 lbs @ 1.780"
380 lbs @ 1.180"
400 lbs @ 1.130
coild bind @ 1.070"
BTW I am reading this as a civil discussion so no need to keep stating that you are not arguing or just having a discussion...I get it. This topic has been brought up many times in the past and can get heated so I know why you making it a point to be mentioned.
Again I have no issue with beehives...I am just convinced after reading posts from and talking with Brian Tooley that duals were the right choice for me. I am by no means a expert so carry on.
I've run both and respect both. And respect your decision to run what you run. I so wish I had a few piles of money sitting around here and could put together an engine dyno. I would run so many back-to-backs I'd probably look like Tom Hanks at the end of 'Cast Away' by the time I saw daylight again.
http://www.superchevy.com/how-to/eng...-valvesprings/
It surely illustrates that there isn't much difference in a controlled test with a certain set of parameters/parts...heck; less than 1%.
A few things that occur to me:
Comp 918 vs. BTR .660 is like the Kia of beehives vs. the Cadillac(well; in my price range at least) of duals.
Were the 918s run with a steel or titanium retainer package? Can make a difference.
Spring rates change after break-in AFAIK. What do these springs look like at 10K miles?
Do you guys know how heavy is the 918 itself compared to, say, a PSI 1511?
Now his ls3 revs cleanly to 7100 rpm
Based on the photos, it looks as though the 918's were run with the factory steel retainers.
The question of a change in rates/pressures with break in is valid, but even if the pressures change after some usage and they free up a few hp, I'd bet the 918's and BTR duals would still be similar to each other.
I feel a bit nit-picky bringing up such slight differences, but at less than 1% HP difference in an environment that is not real-world, we're already in nit-pick land I think.
http://www.enginelabs.com/engine-tec...-work-for-you/
Last edited by kinglt-1; Jul 19, 2016 at 03:54 PM. Reason: Wrong part number on springs
Another thing on dual springs. Same friend with ls3 had a grand am cup 346 years ago. Used dual springs on it and popped the head off the valve....i would not use them at all with a hollow type valve.
Another friend wanted to try my 1.7 harland sharp rockers on his car so i let him barrow them. Keep in mind i had thousands of miles on them with my stock ls6 springs. He had dual springs......didn't take long and they started breaking.
I've had psi 1511 and 1.8 harland sharps on my ls6 for quite a while now with no issues. I've even did the dreaded money shift one night (3rd into 2nd @ wot) and it never missed a beat.
The only thing better than a beehive to me is a conical. Take some good advice and don't try to save $ in your valve train by using a inferior dual spring.
Btw....the psi 1511 has more taper than a oe ls6 spring. It don't look quite as beehivey more conical if that makes sense.
2000 miles so far and no issues. The 1904's are only 150/380, I doubt they are going to break a hollow valve.
Last edited by kinglt-1; Jul 19, 2016 at 03:55 PM. Reason: Wrong part number on springs..
Its not the pressure that beaks them....it's more violence /harmonics in the valve train.
Who knows you may be fine. They may never break on you. But to me any time i can get 1lb or so out of my valve train it's a good thing.....not to mention added stability.
Makes me wonder if some of these broken spring failures we read about are caused by
sloppy mechanics who find a spring compressor, throw different springs on, without as much as even a tape measure, button it up, head to the dyno.
Ha j/k no one does that.
REALLY INTERESTING!!
So this article shows the weight of the 918 Beehive at 99g. Some dual(likely comp also) at 121g.
I weighed stock and PSI 1511(pics below).
PSI 1511: 68g
Stock LS6: 78g
Comp 918: 99g(!!)
Comp? Dual: 121g
PSI saves 10g per spring over factory and a whopping 31g over 918! That's almost 50% more. 496g over 16 springs. I think half a kilo is significant.
No wonder that heavy-*** 918 doesn't show any benefit! I may be closer than I thought on my "Kia of beehives" comment.
What do you guys think?
