quick question regarding dial indicators
Old Jul 25, 2016 | 12:45 PM
spawne32's Avatar
Default quick question regarding dial indicators
Anyone know the PN of a dial indicator kit that will mount to an LS head or anywhere on an LS engine for that matter that I could measure either from the retainer or pushrod?
Old Jul 25, 2016 | 01:02 PM
KCS's Avatar
KCS
Moderator
Most of the indicators have the same 8mm x 1.25mm thread that the LS uses for rocker bolts, header bolts, etc. so they all will bolt on. You just need extra rods and clamps to position the indicator.
I usually just bolt a piece of steel plate or an old cam retainer plate to the front or rear side of the head and mount the magnetic base to it.
Old Jul 25, 2016 | 01:17 PM
spawne32's Avatar
do you know of any dial indicator stands with that thread pattern off hand? I havent been able to find one that uses metric, and most are magnetic bases.
Old Jul 25, 2016 | 01:46 PM
67Lark's Avatar
I have a matco one that has both magnet and vise grip attachment. Any chance you could use vise grip attachment to do what you need?
Old Jul 25, 2016 | 01:49 PM
KCS's Avatar
KCS
Moderator
Harbor Freight. You just undo the locknut and unscrew the rod from the base.
