LS1 Motor for FREE?
Old Jul 31, 2016 | 11:00 PM
boostinbort's Avatar
Default LS1 Motor for FREE?
This is a gf's family member's motor. The motor dropped a valve on cylinder 1. The 1st picture is a crack. I don't know if this is repairable and if so, how to repair it. The motor has been outside since 2012 so the cylinder walls have a lot of rust. just wondering if i can get this thing into running condition again. The second picture is actually a video head inspection and it's tap to play.
Thanks in advance
20160731_171726 by
20160731_171746 by Jack Bort, on Flickr
20160731_171614 by Jack Bort, on Flickr
20160731_171610 by Jack Bort, on Flickr
20160731_171607 by Jack Bort, on Flickr
20160731_171605 by Jack Bort, on Flickr
20160731_171601 by Jack Bort, on Flickr
20160731_171558 by Jack Bort, on Flickr
20160731_171551 by Jack Bort, on Flickr
20160731_171546 by Jack Bort, on Flickr
20160731_171537 by Jack Bort, on Flickr
20160731_171522 by Jack Bort, on Flickr
Old Jul 31, 2016 | 11:24 PM
Mercier's Avatar
Not worth repairing, unfortunately.
Old Aug 1, 2016 | 01:01 AM
1FastBrick's Avatar
It can be repaired, how ever it's going to be costly.
Old Aug 1, 2016 | 02:35 AM
Exidous's Avatar
You're probably better off dropping it off at a metal recycling center. The heads alone should be $40-60 in raw aluminum. It can absolutely be fixed but the route you'd probably want to go is have the whole thing resleeved. At least $2k. If it were left in a garage for 4 years it would be a totally different story.
Old Aug 1, 2016 | 03:56 AM
irrational's Avatar
thats unfortunate, the repair cost to sleeve and repair cracked wall, including decking the block and a new/repaired rotating assembly (Assuming the block caps are not rusted beyond spec as well) would be well beyond what a used good block would cost. Looks like the lifter bores have corrosion inside of them as well, not good.
Crank might be salvageable, possibly rods as well, that head as long as its not too ate up might be fixable too.
Old Aug 1, 2016 | 07:06 AM
KCS's Avatar
KCS
Moderator
Nice looking coffee table...
Old Aug 1, 2016 | 07:45 AM
RockinWs6's Avatar
Reminds me of a perfect Pontiac 400 engine friend took out of a old GTO to do restoration work. Left it out side for 10 years then asked me to look at it.............................................com plete junk
Old Aug 1, 2016 | 03:53 PM
xdanny510x's Avatar
Hot tank it.. and clean and prep it to be a fancy coffee table
Old Aug 2, 2016 | 07:07 PM
Taxman20's Avatar
Boat anchor
Old Aug 2, 2016 | 07:28 PM
Flyingcat's Avatar
NASCAR used to refer to that as "seasoned"!
Old Aug 3, 2016 | 06:33 AM
JoeNova's Avatar
Restricted User
I agree with making it a coffee table.
Old Aug 3, 2016 | 05:15 PM
brandon6.0's Avatar
U could use block for turbo fab or engine swap mockup block.
Old Aug 9, 2016 | 12:34 AM
What do people think about darton sleeving the block and getting bored out pistons , rotating assembly?
Old Aug 9, 2016 | 06:43 AM
Mercier's Avatar
Well sure if the sleeve design you pick goes all the way to the water jacket AND that block isn't compromised anywhere else. Have you priced the sleeves and labor? You're in like $3K+ I think, just for the block itself. Unless this block has high sentimental value or super powers, seems like a steep climb financially. Like modifying a Camaro by making the keys for the Camaro fit in a ZR1.
