Valve spring swap question
If you're going to stick rope in there, use Nylon rope that is as large of a diameter as you can get that still fits in the hole. Nylon will be less likely tear and leave bits in the cylinder.
Do you have a buddy who will loan you a compressor or a place to rent one? I wouldn't try to do springs without one. The valves need to be COMPLETELY closed to get the locks on and I don't know that a rope would do that.
plug hole put it in till you can't fit anymore in
leave some out, rotate crank around easily till it
won't rotate anymore. Don't overthink it.
soft cotton rope works great, I have used that
method lots of times swapping out valve seals.
rope into spark plug hole, if you only get a little rope in, rotate crank till piston moves down some, you want a good amount of rope to get under both valves, doesn't have to be exactly BDC.
You might can look down plug hole with light and mirror, or simply stick something down spark plug hole and see how deep it is, use something stiff but nothing that will scratch,
like the straw on a WD-40 can? When hole is full of rope, GENTLY turn crank till you feel
piston pushing rope against valves, I like the cotton rope because it compresses nice
against valves, of course use clean rope, its cheap at hardware store $5 or 6 in a package.
If you are tearing rope in there you are being a little rough, don't do that.
I like it better than air because you can step away from job if you need to, air will bleed out if you loose air supply, rope is solid. When you are finished swapping whatever,
rotate crank off of rope and pull it out, go to next cylinder. Do 1 cylinder at at time.
When all 8 holes are swapped then start putting rockers back on and finish up.
Hope that was a little more clear than mud.
Someone who hasn't worked on engines before is not getting that cylinder to TDC. They then decide to stuff in 5' of rope or more and realize its not enough and instead of pulling it all out and rotating the crank to get the cylinder in the correct position they decide to just rotate the crank with all that rope in the cylinder. Some of the rope frays on the sidewalls, gets caught in the rings of the piston and now they have a big issue.
Again I am guessing here, but that's about the only way I can see it happening. If they have already removed all the rockers, then all the valves are closed, so I don't see them getting the rope stuck in a valve.
Common sense goes a LONG ways.
