Turned engine over by hand CCW by accident
Old Aug 6, 2016 | 12:26 AM
firstgenon24s's Avatar
Default Turned engine over by hand CCW by accident
I accidentally turned my engine over counter clockwise very slightly, I was reading some things about how this could throw timing off. Should i worry about this? I was completely not thinking when I tried to loosen the crank pulley bolt, the pulley turned for split second and I stopped. Hopefully I'm over reacting?
Old Aug 6, 2016 | 12:28 AM
ElkySS's Avatar
Shouldn't cause any problems. It's fine.
Old Aug 6, 2016 | 12:41 AM
I was hoping so, sometimes you zone out and don't realize what you're doing and then when you do its too late haha.
Old Aug 6, 2016 | 09:02 AM
DietCoke's Avatar
lolwut. you can run the damn thing backwards if you're so inclined to do so.
Old Aug 7, 2016 | 09:35 AM
Taxman20's Avatar
Doesn't hurt anything. It has no clue it went backwards.
Old Aug 7, 2016 | 10:11 AM
Jake75's Avatar
It's fucked! Send it to me its no longer going to work for you.
Old Aug 7, 2016 | 10:29 AM
Honestly guys, I thought the same thing, then when you look up "turned engine over by hand counter clockwise" in google you get a handful of responses about timing issues, jumped teeth etc lol. I saw that and just figured I'd ask people with actual automotive knowledge, especially with these engines.
Old Aug 8, 2016 | 07:08 AM
hammertime's Avatar
It is common practice to rotate the engine in both directions anytime you locate Top Dead Center with a piston stop, as well as when degreeing a camshaft. Won't hurt a thing.
Old Aug 8, 2016 | 10:27 AM
mOtOrHeAd MiKe's Avatar
From: Saskatchewan, Canada - where arguing "DA" is for the slow and weak...
I giggled.
OP, it is okay to ask a legitimate question - even if it seems silly at the time. As you have already figured out don't blindly trust anything Goofle tells you. Now get back to work.
Old Aug 8, 2016 | 11:12 AM
Haha, you're right man. I honestly didn't think it was a big deal, then I hit google and was blown away lol.
Old Aug 8, 2016 | 12:52 PM
67Lark's Avatar
On a simple chain engine like this it's no big deal. It's the DOHC/multi-chain/belt motors that have issues. The tensioners that they use tend to collapse when being spun backwards and then the chain or belt jumps a tooth. But on this simple OHV style there are no issues.
