408 stroker, what heads?
My lq9 started developing a rod knock this morning so its time to pull the trigger on a 408. My local builder is doing it for me, will be an eagle rotating assembly with wiseco pistons. Motor will be roughly 10.5:1 and he will spec the cam out as well. I have a fast lsxr-t right now but was considering selling it to fund some of the build and just going with a tbss intake or something similiar. i know it will kill performance a bit, but it will get me by until i can get something later. For the complete short block assembly and cam kits/ gaskets its $4500, so i need a top end to complete it. I am trying to stay under $6000 for the long block but can budge a little.
So that being said, rectangle or cathedral port? How bad will a set of factory ls3 heads be for it? im on a semi tight budget for heads so cant go all out. I know with my budget it wont be optimal but i can change things later as i get more funds. any incite is appreciated
Moderator
Received 1,852 Likes
Id grab a used set of L92 heads and the matching intake. Make good power, good on the 4.030" bore
Moderator
A LS3 headed/intake 402- 408 usually puts down 510- 540 rdepending rwhp on the compression and camshaft.... 530 being the normal due to most guys would run at least a 240 duration camshaft.
My truck put down if i recall correctly 470rwhp and 450 rwtq.. thru a slipping 4l60e with a hd2 kit ..cam was a 230/244/11lsa
It was a consertative tune.. aggressive tune wouldve been around 490 give or take... didnt want to push it cause i ran out of funds if tranny blew lol
10.5 static compression ratio? Don't even think that way. Don't leave anything on the table, shoot for a higher ratio than 10.5, there are guys running 12:1 with pump gas and a good tune. Build for torque, tune for hp. you won't regret it. My 2 cents.
What were the cam specs?
Im doing my 408 lq9 now. I had different vehicle i plannez it for so its a pretty agressive cam and springs. I might get something else. Its going in my IROC Z QUOTE=xdanny510x;19351063]Btw i had a similar set up ur about to build.. lq9 408 eagle rods n crank and diamond pistons.. compression was 11:8 to 1 tho.. ran like a champ[/QUOTE]
