spring seats, retainers and locks for PSI 1511ML's
Hi I'm building up an Lq4 for use in my turbo truck.
https://ls1tech.com/forums/conversio...ogress-16.html
317's with stock valves and mild port work. valve lift around .620"
I'm looking for recommendations on spring seats, retainers and locks to work with psi1511ml springs and stock valves.
I'm on a budget, but would like a reliable valvetrain that can see 6500 at the track.
Thanks
Thanks
The 1511s are designed to be direct drop-ins for stock, meaning you can use all the same supporting hardware. If you want Ti retainers, I know BTR sells some stock-replacements made of Ti for about $100 for a set. At 6500, I don't think you'll benefit much from it though.
