Daily driver / toy cam
From: Coast of San Mateo County Between Pacifica & HMB
As mentioned lift to high for stock head flow (.590" is plenty)
,stock rockers,(.620" max with trunion or bushing upgrade)
also need stronger springs to control, and
Exhaust split is at least 4* if not 6* to big unless adding
150-200 N2O, should have 11.00:1 comp as well.
Cam Motion LS1 Titan 3 or 4, or BTR LS1/2 Stage 2,
Any of those 3 would perform much better for your application
as well as last longer and be more reliable
(more stable valve train).
In my opinion.
In my opinion.
I'm looking at possibly buying a used cam with the same specs as the one listed in the OP. I currently have a stock 853 headed LS1 bolted to a 4L80E in a 94 Camaro, and eventually want to spray it some. Is the cam way to big for a stock headed motor or would it work okay for a bit? I really just want something to make the car a bit more fun till I can work up a turbo setup.
