compression test slow build up
Old Aug 17, 2016 | 12:49 PM
apiazza2010's Avatar
Default compression test slow build up
I have a 02 ls1 with HCI, I did a compression test, I am getting 180 values on all cylinders.
The problem I'm having is it's very slow in building pressure.
Is this normal ?
Old Aug 17, 2016 | 12:55 PM
G8One2's Avatar
I would suspect valves are not sealing well. Usually it jumps to 90 or higher on the first pulse if you have good sealing valves.
Old Aug 17, 2016 | 02:15 PM
squarles67's Avatar
Do you have the throttle body or carb wide open?
Old Aug 17, 2016 | 02:20 PM
00pooterSS's Avatar
That's odd. Are you having a problem? If not I would suspect the gauge itself or the way you are doing the test. Make sure you have the throttle body or carb open (pedal to the floor) like stated above.
Old Aug 18, 2016 | 11:38 AM
I just tried the test again with the throttle body wide open and it does the same thing.
The car runs well, I'm putting it up for sale and want to disclose the compression numbers to buyers.
Can i test if the valve are not sealing well?
The test shows about 180 for all cylinders
Old Aug 18, 2016 | 02:15 PM
squarles67's Avatar
Could just be the gauge.
Have anyone you can borrow a gauge from?
Autozone and Oreilly have loaners
Old Aug 18, 2016 | 05:32 PM
finewayne's Avatar
check the carb maybe?
Old Aug 19, 2016 | 03:45 PM
Darth_V8r's Avatar
Moderator
Put a squirt of oil in through the sparkplug hole. If it builds faster, the rings are the issue. If not, then it's likely the valves.
Old Aug 27, 2016 | 08:44 PM
Chevy Guy's Avatar
This - always do a compression test with the throttle wide open.
