What went wrong here?
No, it did not hurt anything, you can spin it any way you want while working on it.
When trans. was out, engine may have tilted and messed up cam sensor.
have to do with each other?
Pushing the crank forward in the block will cause the cam/crank sensor (depending on Gen of motor) to lose connection because the crank has walked away from them. My cousin built an aluminum block 402 stroker for a guy and he decided to change converters about a week later and didn't get it in right, walked the crank, had backfires and bad timing and ended up wiping out the block.
So now you answer me...what does that have to do with the OPs issue?
No doubt...but it should be easy to turn by hand to line up the first bolt. That was my point. I've pulled plenty enough transmissions to know how easy it is to get wrong.
