push rod length please help!!
-https://ls1tech.com/forums/generation-iii-internal-engine/1814456-how-wipe-pattern-roller-rocker-pushrod-length.html#post19085422 Start with post #13 and read, re-read this several times. You do not need to torque anything to 22ft/lb yet.
-Use calipers instead of pushrod checker turns to measure the length.
-Mine were all 7.48x at zero lash. I'm using different lifters and PRC 225 heads.
-TSP also told me to use 7.450 length, but after measuring I decided to be more precise and ordered 7.525".
So your longer zero lash measurement isn't out of the ordinary, depending on your setup. I know exactly how you're feeling, because I was doing the same thing. Best bet is to forget what you're doing and follow the guide step by step. It'll click and you'll be in good shape.
The rotation should only be used to confirm the measurements with the calipers
Oh, and when you order make sure to tell the vendor you measured overall length with calipers. They'll make any necessary adjustment.
