Quick Head Question
Old Sep 21, 2016 | 09:53 PM
cbrpilotguy's Avatar
Default Quick Head Question
Newbie head question here. So I'm buying a 2002 WS6 soon and the guy I'm getting it from told me that the previous owner installed ported and polished 5.3L heads on it. Aside from pulling off the intake, is there any way of telling if the heads are cathedral port or square port? Any input would be helpful. Thanks!
Old Sep 21, 2016 | 11:39 PM
KCS's Avatar
KCS
Moderator
There's a casting number on the corner of the heads. The 5.3L heads are usually a 706 or 862 casting.
Old Sep 22, 2016 | 08:10 AM
Aaron at SDPC's Avatar
Like KCS mentioned a casting number should be located at the corner of the heads.
Old Sep 22, 2016 | 08:27 AM
farmington's Avatar
FWIW if someone uses the phrase "ported and polished" it USUALLY means they don't know their *** from a hole in the ground.
Old Sep 22, 2016 | 08:36 AM
HCI2000SS's Avatar
Yep mine are 5.3 heads and have 862 stamped on mine
Old Sep 22, 2016 | 04:09 PM
So from what I researched, all 5.3 heads are cathedral port heads? I will look for the casting number when I got pick up the car this weekend.
Old Sep 22, 2016 | 04:19 PM
Yes every cylinder head on the 5.3s were cathedral port.
Old Jan 9, 2017 | 11:58 PM
darren roar's Avatar
Dumb question. What are the difference between a 706 and a 862 head?
Old Jan 10, 2017 | 07:20 AM
KCS's Avatar
KCS
Moderator
Some of the 862 castings were castech heads, which had a tendency to crack around the bolt holes and weep coolant. I don't think any of the 706 heads had that problem.
Some have a void, for lack of a better word, cast into the deck. Those require a specific head gasket, but I think both castings came that way at some point and that it was more dependent on the year and not so much the casting number.
Old Jan 10, 2017 | 07:21 AM
JoeNova's Avatar
Restricted User
I thought it was the other way around? The 706 heads were the Castech heads with failure problems.
I've never had an issue with the castings, but I do have 2 sets of 706 heads with the Castech logo on them.
Old Jan 10, 2017 | 09:17 AM
KCS's Avatar
KCS
Moderator
You might be right about that.
Old Jan 10, 2017 | 01:07 PM
gagliano7's Avatar
The 706 castech heads had the problems. I never heard of any of the 862 heads having the same problems.
Old Jan 10, 2017 | 01:42 PM
2ToeRacing's Avatar
I'm sorry,I just have to say it.......I always have a " head question"
