LS1 Intake & Exhaust Valves
Recently noticed james bond-esque smokescreeen on high rpm decel, and after C&L was performed things are pointing towards the exhaust valves. I figure while I'm in there, I'll do the intake valves too.
Is there anything else recommended to do while I'm in there? Preventative maintenance as well as performance/upgrade.
Also if there is a recommended brand to purchase feel free to chime in with that.
Thanks
Hint: same head design that came on the Z06 in your same year. Those heads, along with the LS6 cam, resulted in your same basic short block making a lot more power.
If you just want the answer to your question, Manley makes great valves but you'd still need a valve job to make sure things seal up to the existing/factory/older valve seats in the heads.
I also figured since I had the valve covers off, I'd do the intake seals as well as a preventative measure.
Stock type:
http://www.briantooleyracing.com/ls-...hat-style.html
Aftermarket style:
http://www.briantooleyracing.com/ls-valve-seal-kit.html
The 243 heads are not some radically different design; they are functionally similar to a LS1 head in every way save for a slightly smaller chamber and better-flowing ports. Any cam that worked well for a LS1 head will likely work even better with a LS6/2(243) head. These also came on trucks as 799 castings. Same thing.
See here for the tool you really must get to make sure you don't jack up your new seals(and pull off the little springs before install!):
https://ls1tech.com/forums/generatio...eal-depth.html
